Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-09-2013, 09:39   #1 (permalink)
Member: 1640892
Sonork: 100.1651734
Thanks Meter: 25
Nokia 1oo locked
help on how to unlock nokia 100
sreenshot
MCU: V 03.60 17-11-11 RH-130 (c) Nokia
IMEI: 354587054807845
Product Serial Number: 6408CBEBI
Product Code : 059P270
Module Code : 0204875
Basic Production Code: 059N126
PPM SW Version : V 03.60 17-11-11 RH-130 (c) Nokia AE
ADSP Version : p V 03.60\n17-11-11\nRH-130\n(c) NMP\nae
MCU SW Version : V 03.60 17-11-11 RH-130 (c) Nokia
HW Version : 3051
UEM Version : 1328
UPP Version : 8850
LCD Version : TPO:BARACOAv90 HX5081
********** SIMLOCK INFO **********
CONFIG_DATA : 2280200000000000
PROFILE_BITS : 8000000000040002
ASIC : 11
PROVIDER : Sunrise Communications AG;Switzerland [GSM]
Block [1] 1:Close
Block [2] 1:Close
ST_LCD_TEST : PASSED
Make sure you have installed the
COMPLETE Flash Package for this Phone...
Goto "Settings" --> "Nokia Settings" and verify that
the Folder where you installed your Flash Files are
in the "PRODUCT PATH TO SCAN" List...
br
barugatec
Old 09-09-2013, 10:04   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Decrypt PM120 Hash from this phone, if phone is 20-digit then
ATF will not make LBF files, if phone is 15-digits then files will
be made and you can upload ATF Server 35xxxxxxxxxxxx.job file
for 20 ATF BF Credits in order to get Master Code of this phone.
Old 09-26-2013, 14:30   #3 (permalink)
powerplay83's Avatar
Member: 753732
Thanks Meter: 252
i have bought Nokia 100 / 101 FFS PRO2 Fbus Cable , i cant not scan the Phone
there are 3 settings, MT , Cyclone , UFS,
i select UFS
i Plug the cable in Extension Port, and try 5,1k, 7,5k, 10k
it will not work.
some can help ?
VBATT Powering Down <<<<
VBATT Powering Up   >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
SET BSI Load Done
Booting Phone...
SET BSI Load Done
Booting Phone...
SET BSI Load Done
Booting Phone...
SET BSI Load Done
Booting Phone...
SET BSI Load Done
Booting Phone...
ERROR: Phone did not Boot !!!
 Make sure that you plugged the cable to the
 RJ-45 Port Marked << EXTENSION >>
  ||  FLASHBUS                EXTENSION  ||
  ||  |       |  (O) (O) (O)  | CABLE |  ||
                               PLUG IN
                              CABLE HERE
 Try booting this phone with "Live Phone" option
 Check the option beside the "Scan Phone" button
Flashing ERROR
ERROR : PHONE READ INFO FAILED
Old 09-26-2013, 16:02   #4 (permalink)
Member: 643472
Sonork: 100.96901
@powerplay83:
Bus Check phone first and then click Scan Phone button.
Old 09-26-2013, 17:17   #5 (permalink)
Member: 1892909
Sonork: 100.1647570
Thanks Meter: 39
dear plz cheak your expention port and then chek cable then do bus chek solve
....it,
Old 11-26-2013, 08:53   #6 (permalink)
Member: 753732
Thanks Meter: 252
sir my old advanca box was damaged, i have bought new ATF nitro.
i want unlock Nokia 100
it hangs on : SBL Successfully Sent...
08:48:48 : Waiting for Phone to Go Online...
08:48:49 : Elapsed Time: 1s
08:48:50 : Elapsed Time: 2s
08:48:50 : ERROR: Read PM Failed
08:48:50 : NO PHONE DETECTED/PHONE DISCONNECTED
08:50:23 :
08:50:24 : MCU: V 04.30 18-09-12 RH-130 (c) Nokia
08:50:24 : IMEI: 35895xxxxxxx
08:50:24 : Product Serial Number: 1FF9975BH
08:50:24 : Product Code         : 059L5W8
08:50:24 : Module Code          : 0204881
08:50:24 : Basic Production Code: 059R191
08:50:24 : PPM SW Version       : V 04.30 18-09-12 RH-130 (c) Nokia AD
08:50:25 : ADSP Version         : p V 04.30\n18-09-12\nRH-130\n(c) NMP\nad
08:50:25 : MCU SW Version       : V 04.30 18-09-12 RH-130 (c) Nokia
08:50:25 : HW Version           : 1001
08:50:25 : UEM Version          : 1328
08:50:25 : UPP Version          : 8850
08:50:25 : LCD Version          : TPO:BARACOAv92 HX5081
08:50:26 :   ********** SIMLOCK INFO  **********
08:50:26 : CONFIG_DATA  : 2620700000000000
08:50:26 : PROFILE_BITS : 8000000000040002
08:50:26 : ASIC         : 11
08:50:26 : PROVIDER     : O2 (Germany) GmbH & Co. OHG ;Germany [GSM]
08:50:26 :
08:50:26 :    Block [1]  1:Close
08:50:26 :    Block [2]  1:Close
08:50:26 : ST_LCD_TEST               : PASSED
08:50:26 :
08:50:30 :
08:50:30 : Make sure you have installed the
08:50:30 : COMPLETE Flash Package for this Phone...
08:50:30 :
08:50:30 : Goto "Settings" --> "Nokia Settings" and verify that
08:50:30 : the Folder where you installed your Flash Files are
08:50:30 : in the "PRODUCT PATH TO SCAN" List...
08:51:53 : VBATT Powering Down <<<<
08:51:55 : VBATT Powering Up   >>>>
08:51:56 : SET VCCIO Level Done
08:51:56 : SET BSI Load Done
08:51:56 :
08:51:56 : Booting Phone...
08:51:56 : CPU ID Response: A200341100
08:51:56 : CPU Type: XG110 2.1B
08:51:56 : Phone Booted at after First attempt...
08:51:56 :
08:51:56 : ******************************************************
08:51:56 :              START INFINEON BUS CHECK
08:51:56 :
08:51:56 :
08:51:56 : Sending PBL 37888 bytes...
08:51:56 : PBL Successfully Sent...
08:51:56 : Unique Data: A0D08421062005829202
08:51:56 : Sending SBL 65024 bytes...
08:51:57 : SBL Successfully Sent...
Old 11-26-2013, 09:04   #7 (permalink)
timiG's Avatar
Member: 198519
Sonork: 100.1604680
Thanks Meter: 63
@powerplay83
nokia 100 has nck 20. can not be decoded by lbf .
only code from operator ,in your case O2 Germany .
br.
Page generated in 0.21708 seconds with 8 queries
