02-02-2014, 17:43 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Error flash Lumia 520.2 Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Boot Flash Mode Successful... Phone Info Query Start... Checking SD Card Size... Card Size: 0x41204669 Checking Platform Security Status... Platform Secure Boot Status: Not Active Secure FFU EFUSE Status: Not Active Debug Status: Not Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Not Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 412046694E7274206F2020202020206F4C69676F4365723120 2E302E333038010A55151CBC22A6D9BE70916E748E81000000 00000000000000000000000000000000000000000000000000 000000000000000000 Flash App Protocol Version: 32.70 Flash App Implementation Version: 105.78 Query ROOT KEY HASH... ROOT_KEY_HASH: 412046694E7274206F2020202020206F4C69676F4365723120 2E302E333038010A55151CBC22A6D9BE70916E748E81000000 00000000000000000000000000000000000000000000000000 000000000000000000 ERROR: Flash File ROOT_KEY_HASH Mismatch! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! I usse latest firmware for my product code |
02-02-2014, 18:53 | #2 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== IMEI: 35592505XXXXX13 Version: 1.1.1.3 Product Code: 059S3M1 Module Code: 0205437 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E74000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010E011900 UEFI App: FLASH APP Flash App Protocol Version: 1.14 Flash App Implementation Version: 1.25 Query ROOT KEY HASH... ROOT_KEY_HASH: 7C81AABA97E4904DB782605A6C74A59480361E5A363337B2EF 5B8F925763110B Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... ERROR: DATA BLOCK REJECTED at 0x43F80000 Check your Flash File and Phone Connection ERROR: Flashing Failed! Flash file ok, cable original perfect, battery is full |
