Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-08-2014, 11:42   #106 (permalink)
Member: 755804
Thanks Meter: 91
Can someone help with Greek flash file?
Old 12-28-2014, 16:52   #107 (permalink)
Syifa.Cell's Avatar
Member: 624037
Sonork: 100.1608764
Thanks Meter: 41
ane juga lagi nyari yang Indonesia language, ga dapet, try reading from a live phone, but the log is:
INFINEON BUS CHECK DONE
Detected Phone Type: RM-908
MCU File Saved:
C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\rm908_03.400
PPM File Saved:
C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\rm908_03.40me
CNT File Saved:
C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\rm908_nai03.40me
VPL File Saved:
C:\AdvanceBox Turbo Flasher\Nokia\Recovered\RM-908\RM908_059T2V1_03.40_001.vpl
Performing Final File Checks...
MCU File is OK...
ERROR: PPM File is Incomplete!
Deleting PPM File...
CNT File is OK...
Flash Files Dump Success!
Old 01-24-2015, 06:13   #108 (permalink)
Member: 883248
Sonork: 31111
Thanks Meter: 7
this is flash arabic - english -fracais - portugues language only tested 100%
v3.40
v4.35
solve local mode
download from 4shared
105 rm-908 v4.35 arabic tested 100% - Download - 4shared - mostafa elpery
105 rm-908 v3.40 arabic tested 100% - Download - 4shared - mostafa elpery
(Y)
Old 01-29-2015, 10:07   #109 (permalink)
skyulock's Avatar
Member: 757064
Sonork: 11111111
Thanks Meter: 365
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer ID: 0x00EF
Flash Chip Type: 64 Mbit (4Mb x 16) NOR
Extended Information: Multi-Bank / 1.8v
Processing Image File: C:\Users\user\Desktop\RM-908_v02.70_059R449_Arabic_Urdu_English\RM-908_059R449_Arabic_Urdu_English\rm908_02.700
Data Block Found...
Number of Sections: 03
IMAGE Certificate Block Sent Successfully...
Processing Section 01 of 03
IMAGE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: 0551
Uploading Data Blocks to phone...
IMAGE Data Blocks uploaded to phone...
Processing Section 02 of 03
IMAGE Erase Block: 0x00C60000~0x00EAFFFE
Start Erasing...
Block Erase Done...
Data Size: 2232896 bytes
Data Checksum: 89F6
Processing Section 03 of 03
IMAGE Erase Block: 0x00FFC000~0x00FFFFFE
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Users\user\Desktop\RM-908_v02.70_059R449_Arabic_Urdu_English\RM-908_059R449_Arabic_Urdu_English\rm908_02.70ij
Data Block Found...
Number of Sections: 01
Processing Section 01 of 01
IMAGE Erase Block: 0x00210000~0x0039A33E
Start Erasing...
Block Erase Done...
Data Size: 1614656 bytes
Data Checksum: 6B15
Processing Image File: C:\Users\user\Desktop\RM-908_v02.70_059R449_Arabic_Urdu_English\RM-908_059R449_Arabic_Urdu_English\rm908_nai02.70ij
Data Block Found...
IMAGE Erase Block: 0x00EB0000~0x00F161BE
Start Erasing...
Block Erase Done...
Data Size: 418240 bytes
Data Checksum: 7E6F
Exit Flash Mode Done...
Time Elapse : 00:01:57
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 02.70 22-02-13 RM-908 (c) Nokia
IMEI: 351750069292030
Product Serial Number: F4EB6CEBI
Product Code : 059R454
Module Code : 0205453
Basic Production Code: 059T865
PPM SW Version : V 02.70 22-02-13 RM-908 (c) Nokia IJ
ADSP Version : p V 02.70\n22-02-13\nRM-908\n(c) NMP\nij
MCU SW Version : V 02.70 22-02-13 RM-908 (c) Nokia
HW Version : 2000
UEM Version : 1328
UPP Version : 8850
LCD Version : WIN:BEIHAIv82 ILI9163C
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000040002
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : PASSED
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
Old 02-01-2015, 11:15   #110 (permalink)
Member: 2336317
Sonork: 9974200963
atf box jtag all usesher 39 credite free
pls..help
Old 02-04-2015, 11:53   #111 (permalink)
Member: 1844616
nokia 105 flash any version its will be ok tested 1000 by me
your phone v4.35 flash any low version phone will be ok
Old 02-04-2015, 12:05   #112 (permalink)
Member: 1844616
Old 02-05-2015, 20:46   #113 (permalink)
Member: 1878155
please how do get the Manuel
for volcano flashing box
Old 03-08-2015, 13:28   #114 (permalink)
sanjubhai's Avatar
Member: 386868
Thanks Meter: 125
Originally Posted by srinibas View Post
First in the World ATF present Nokia 105 RM-908 flash file
Download link - https://forum.gsmhosting.com/vbb/****************************/?sq65nht8s258d7k
Software Version : 2.70
Product Type : RM-908
Arabic + Urdu + English
Br - srinibas
working very fine
sanjubhai.
Old 03-16-2015, 01:27   #115 (permalink)
Member: 1580119
Sonork: baby
Thanks Meter: 7
pleace help i need nokia 105 rm-908 v3.40 me, thanks
Old 03-19-2015, 13:01   #116 (permalink)
Member: 252706
Thanks Meter: 6
Nokİa 105 rm-908
Please add the nokİa 105 (rm-908) turkİsh flash fİle
please
thank you so much.
Old 05-27-2015, 07:40   #117 (permalink)
Member: 924142
Thanks Meter: 12
nokia 105 indonesia language pack shared ,please
Old 07-17-2015, 13:03   #118 (permalink)
Member: 410020
Thanks Meter: 14
thanks brods......
Old 09-03-2015, 19:43   #119 (permalink)
Member: 1500821
Thanks Meter: 5
Hi
need ukraine lng
PPM XX.XXei
PLS help
Old 09-19-2015, 13:21   #120 (permalink)
Member: 1688036
Good afternoon
We have been trying to flash Nokia 105 with spanish pack with advance turbo flasher (serial number BOX_SN8FF546D6)
I try first with one the code 059R451, a new code I never see before and the flash coudnīt be done
After I try with 059R488 and works but just once
I thought it was because of the differents codes of the phones
later on I tried and just sometimes the program works properly (5% of the terminals aprox.) independient of the phone codes
the program it seems is ok and updated
the cable is in perfect conditions
I donīt really can understand wich one is the problem, all telephones start to be flashed but at one point, always the same one, the process stoped and when I try to close it it said "access violation at adress 00B2683C in module "AdvanceBox.exe". Read of adress 7FF8192C (I can send you pics by skype if u need) I tried in 2 differents computer and both same.Can u help me?
Page generated in 0.22613 seconds with 9 queries
