01-19-2016, 08:23 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | how to boot repair rm-1030? I have the set with RM-1030.product code 059v6s5. as per the product code it is V1. So ,when I go to the folder it has so many file avilable to select... To repair phone. need to check V1 or V2 via product code.....it ok V1 now atf jtag select the file---which file I want to select because 6 files available. Please advice me Thanks. |
01-19-2016, 17:55 | #3 (permalink) |
No Life Poster Join Date: Sep 2008 Location: with mobile phone Age: 35
Member: 866865 Status: Offline Sonork: 1645198 Thanks Meter: 182 | it may help you C:\AdvanceBox Turbo Flasher\Phones\Nokia here you can find files for boot repair if there is no file which you want to repair you can download it from Jtag update area see pics XL have two vertion and V2 will named as "fullboot repair V2" others are for V1 hope your problem solved press thanks if it helps |
The Following User Says Thank You to Pratheesh T K For This Useful Post: |
01-20-2016, 06:38 | #4 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
Thanks. | |
01-20-2016, 10:37 | #6 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | @ATF Supoort You put 6 files for V1...and no details of this file what for... Cloud you please give the details to select the correct file. BECAUSE I DON'T WANT to damage the phone by the wrong file Thanks. |
01-22-2016, 23:57 | #7 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | if phone connects holding vol- then just flash it using v1 flash file (product codes containing 059v= V1 hardware ,and ones containing 095w= V2 hardware) but if phone can't connect then repair boot using v1 repair file you won't damage phone anyway while repairing boot it's already dead |
01-24-2016, 09:32 | #8 (permalink) | |
I know that v1 and v2. don't you know how to read ....Problem is if I select the file I got error. fpr again There are 6 file available to repair for v1. but don't know which file to select. If I select file I got error.... But Any How... I have fixed it .but no proper way...even I don't know still that 5 file for what..... I put one by one......and one file is work other files gave me the error. This is not the way to repair the phone.. ATF is good....but no detail instruction for their own file. Thanks. | |
01-24-2016, 15:37 | #9 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: CHOLOMAN
Member: 1440339 Status: Offline Sonork: 100.1616914;CHOLOMAN Thanks Meter: 116 | Quote:
I think u want to know which one have to resurrect? NOKIA_XL_RM-1030_FULL_BOOT_1.1.0.6.afp NOKIA_XL_RM-1030_FULL_BOOT_1.1.1.0.afp NOKIA_XL_RM-1030_FULL_BOOT_1.1.1.4.afp NOKIA_XL_RM-1030_FULL_BOOT_1.2.1.2.afp NOKIA_XL_RM-1030_FULL_BOOT_1.2.3.1.afp NOKIA_XL_RM-1030_FULL_BOOT_1.2.3.2.afp If so. Then YOU can use any version of .afp according to your downloaded flash file version which have to paste xxx:\Program Files\Nokia\Phoenix\Products\RM-1030 In one words 1.1.0.6.afp is suitable to 1.1.0.6 flash file. | |
The Following User Says Thank You to .::JYOTIRMAY::. For This Useful Post: |
01-26-2016, 08:27 | #10 (permalink) | |
also all files are not work...the last two files on error log Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...Shift IR Error(s) Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! the 1 and 2 also error...but 3 file ok 100% Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D4201F35CDA2C614B Flash Description: Samsung J5XWMB, 3.64 GiB, SN F35CDA2C, Jun 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91972 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 1m 28s. Code Download Speed 233 KiB/sec. Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== That is the problem...I have faced. Thanks to all. | |
The Following User Says Thank You to sky_finder For This Useful Post: |
