01-08-2016, 10:41 | #1 (permalink) |
Freak Poster Join Date: Jul 2015 Location: India kerala
Member: 2429238 Status: Offline Sonork: 7736828392 Thanks Meter: 70 | How to Repair LUMAI 520 Unable To find Bootable Option ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D384732594300714C655D606B CSD : D02701320F5903FFF6DBFFEF96406007 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 714C655D Manufactured : June 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D384732594300714C655D606B.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Writing MBR + GPT... Write Success! Writing SBL1... Write Success! Writing SBL2... Write Success! Writing SBL3... Write Success! Writing UEFI... Write Success! Writing RPM... Write Success! Writing TZ... Write Success! Writing WINSECAPP... Write Success! BOOT Images Written Successfully! BUT SAME CONDITION |
