How To Unbrick I8200 - (SUCCESS STORY + BOOT FILES + VIDEOS INSIDE) Hi to all how to repiare boot samsung i8200 ? this phone flashed by correct flash file help me |
But just way up now is desoldering emmc and program it ... |
This phone eMMC NO NEED to desilder from PCB. Only need correct PINOUT and correct Vcc 3.3V and VccQ 1.8V. If emmc cannot be detected, then it means you are using wrong pinout or maybe using a wrong power supply. Use search button, I already posted pinout and I have this phone with me as well. Even totally empty emmc USER, BOOT1 and BOOT2 can be detected by any ATF Box with eMMC Tool. The correct adapter to use is still Smart GSM 4-in-1 V2. If you buy clone adapter or other brand then maybe you will get problems with this phone. |
But we test it and post result here... |
Is this pinuot correct ? Code: http://oi57.tinypic.com/2vj6jhx.jpg |
There are 2 point with write CMD, one of this must be CLK point, (i think is no in resistor), need to ceck with Atf pin finder... BR allumts |
I modify pinout and told him for checking.... but is possible no pinout for CLK on PCB? becuse some users and admin told in this forum not possible for direct emmc.... also Mr Babak Nuri in one post told user that he can repair boot of this model just by USB cable and that solution is private.... whats iss your edia about this solution? |
Here is Atf section and no section of RIFF box. You have full answere from OUR Admin "Advance Box" above, so who listen you @Babak Nuri or our Admin that have wrote clear that is possible try with eMMc direct? What say other peoples not import, just read other time here: Quote:
And not change the thinghs, here nothingh to talk about USB cable. |
http://forum.gsmhosting.com/vbb/10832160-post6.html I copy it for my forum user and wait for his response ... Thanks. |
not detect in atf |
First,Of Course This is not RIFF Section and we never speak about that. Then,I never say I8200 Can't Detect and Can't Work Via ATF...For Sure Can Work Because I did repair many I8200n (over 50pcs) by ATF I say in Easy-JTAG Section about this tool can't detect I8200 CPU http://forum.gsmhosting.com/vbb/10810232-post26.html Also I say I8200 CPU can't Halt over JTAG With RIFF Box,(Ofcourse in RIFF Section) http://forum.gsmhosting.com/vbb/10862649-post2.html And Finally.Yes I Have Signed Loader For Repair EMEI Loader Based Phone Just With USB Cable So.Please Next Time Read Carefully what people say,Then Answer Them Thanks Best Regard ATF Team |
Hi, i not have wrote nothingh of wrong about you. You are good developer in Riff box and these thinghs and if i've need for my RIFF i ask you or Legija or post in Riff section, is right. Here i've only replied to the user becouse there's Full answere above by @X-Shadow and him was continue posting one photo of Pinout with 2 CMD point, w/o CLK. Now, here are reading Atf User and seeing this photo where fault CLK and have 2 CMD point, will have posted ....Why, Where are CLK...Wires for ATF itc... About this: Quote:
P.d. if you loock good, him has Quoted "X-Shadow" for his doubts...has quoted to me only about the 2 CMD point and no CLK. About answer this user, in very many post his is replyng on all, often with wrong solution, so for me any problem and all clear BR allumts |
Hi You are smart man... Totally you right..we never can lost "Clock"...Also ATF used 2 pin of RJ-45 for Best result of Clocking(Can use 1pin or 2 pin).....This is Stupid question about 2 CMD |
The complication about connecting this phone via eMMC is always POWER problem for most users. The VccQ sink a lot of mA because other chips on the PCB is "stealing" power from it. So if your VccQ source is a tiny 20 mA voltage regulator feeding off the USB port, then it will cause problems. However, if you use correct emmc power adapter or use external power supply, then problems will go away. |
@ALL See short video showing GT-i8200 connecting with ATF Box via Original SmartGSM 4-in-1 V2 adapter. http://174.120.45.27/tmp/GT-i8200.MOV |
