01-19-2016, 07:43 | #1 (permalink) | |
Freak Poster Join Date: May 2015
Member: 2399952 Status: Offline Thanks Meter: 40 | huawei g510 EMMC is readonly done by ATF Quote:
The Following 7 Users Say Thank You to sajid8282 For This Useful Post: |
02-05-2016, 08:23 | #5 (permalink) |
Member: 2399952 Status: Offline Thanks Meter: 40 | yes bluffmaster the phone was stuck on logo. and i updating firmware by Memorycard . but the phone show Error on display (emmc is read only you can not update ur system) and then i remove the write protection of emmc via ATF . and my Problem is solve :-) |
The Following 2 Users Say Thank You to sajid8282 For This Useful Post: |
08-07-2016, 08:41 | #7 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | one more EasyJtag Suite ver.: 2.2.0.2 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7600). undefined Android Explorer ver.: 1.0.0.6 eMMC ODIN ver.: 1.0.0.8 Successfully connected to box on COM116 Box S/N: 1700301674F4C181, ,FW Ver.: 01.55 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA84-83AE , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : ACTIVATED, Upgrade it! Z3X Card Activation [JTAG] : ACTIVATED Config set from shell : Vendor:SAMSUNG Model:GT-I9000 Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 1700301674F4C181, ,FW Ver.: 01.55CMD Pullup Level:2031 mV CMD Active Level:2299 mV Box IO Level:3300 mV CLK Rate:7000 khz HiPower mode is off! ---------- eMMC Device Information ----------EMMC CID : 150100534A5330304103D1450B71C034 EMMC CSD : D02701320F5903FFF6DBFFE78A406032 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2013 Rev.0x3 EMMC NAME: SJS00A , S/N: 3510963057 EMMC NAME (HEX): 534A5330304100 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 1024 kB EMMC ROM3 (Boot Partition 2) Capacity: 1024 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: SJS00A_3510963057_20160807_1231.extcsd Done. Running:SAMSUNG: Remove Write Protection...Z3X EasyJtag Software ver. 2.2.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mVCMD Active Level:2299 mV Box IO Level:3300 mV CLK Rate:7000 khz Removing write protection... Done. Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 1700301674F4C181, ,FW Ver.: 01.55CMD Pullup Level:2083 mV CMD Active Level:2815 mV Box IO Level:3300 mV CLK Rate:7000 khz HiPower mode is off! ---------- eMMC Device Information ----------EMMC CID : 150100534A5330304103D1450B71C034 EMMC CSD : D02701320F5903FFF6DBFFE78A404056 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2013 Rev.0x3 EMMC NAME: SJS00A , S/N: 3510963057 EMMC NAME (HEX): 534A5330304100 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 1024 kB EMMC ROM3 (Boot Partition 2) Capacity: 1024 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: SJS00A_3510963057_20160807_1232.extcsd Done. |
