09-14-2014, 18:26 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | i9300 normal factory fomate not responds... eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501003030303030305620110726 CSD : 902701320F5903FFF6DBFFEF8A404023 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 17179869184 BYTES BOOT PARTITION SIZE: 512 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : 000000 Product Rev : 5.6 Product SN : 20110726 Manufactured : January 2005 Card Specific Data CSD_STRUCTURE : Version 1.2 SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501003030303030305620110726_D238ABD1.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Normal Factory Erase ================================================== ==== For eMMC Revision 1.2 (for MMC v4.2) and LOWER --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB For eMMC Revision 1.3 (for MMC v4.3) and HIGHER --> This will ONLY ERASE USER AREA ================================================== ==== This eMMC is: Revision 1.5 (for MMC v4.41) 100 scond pass emmc still busy if me say no than error Task Selected: Normal Factory Erase ================================================== ==== For eMMC Revision 1.2 (for MMC v4.2) and LOWER --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB For eMMC Revision 1.3 (for MMC v4.3) and HIGHER --> This will ONLY ERASE USER AREA ================================================== ==== This eMMC is: Revision 1.5 (for MMC v4.41) Block Write Busy Timeout ERROR: ERASE_USER_AREA FAILED 0x02 |
