12-11-2015, 11:03 | #1 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | kmvyl000lm direct emmc, need clarifications i'm trying to recover data from an i9100 emmc model kmvyl000lm. Chip was removed from the board, and i soldered wires to the chip directly. I had problems at first because the pinout found on google is not the same for this particular chip, but at the end i have found the correct pins. Problem is.. ATF cannot connect to this emmc either.. it give me the error : emmc was not detected (CMD1) , check testpoint. Off course i have checked and checked again the test points, and the connection (continuity) between test point and smartgsm adapter board, all is good. This mean that the emmc is dead ? I should try to repair it through RE pin but i hope this will not mean that all the data will be lost.. because i need to recover data from user partition. thank you ATF Team! |
12-11-2015, 17:21 | #2 (permalink) |
Freak Poster Join Date: Apr 2007 Location: malang indonesia
Member: 480385 Status: Offline Thanks Meter: 16 | here my friend ,i have check manualy by remove emmc http://www.4shared.com/download/uye6...295d&lgfp=3000 |
