12-29-2015, 12:16 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: in ur soul
Member: 234349 Status: Offline Thanks Meter: 227 | lg g4 ls991 dead via doungrade connet ok to atf emmc and ihave LS991ZV6_00 tot file which i have extarted via boarddiag 2.99c i have got all files here r files names aboot abootbak backupgpt boot factory hyp hypbak laf misc moderm partion (its a note pad) persist pmic pmicbak primarygpt raw_resources raw_resourcesbak rct recovery rpm rpmbak sbl1 sbl1bak sdi sdibak sec system tz tzbak userdata now to to write or which file i have to write so my handset will be in dounload mode plz share model number ls991 ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 11010030333247373400524D19554211 CSD : D02700320F5903FFFFFFFFE78640009B eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 31268536320 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 032G74 Product Rev : 0.0 Product SN : 524D1955 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 11010030333247373400524D19554211.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
The Following User Says Thank You to sayyedikram For This Useful Post: |
