11-23-2016, 03:32 | #1 (permalink) | |
Junior Member Join Date: Apr 2015 Location: Taiwan
Member: 2375706 Status: Offline Thanks Meter: 0 | Lumia 1020 restore boot successful but still can't start it. My Lumia 1020 just get a boot error again, so I did the restore boot process by JTAG, and seems like successful, but I still stuck at logo process then reboot again(but it didn't show the boot error note). Here is my restore boot process: Quote:
And is there any way I could backup the file in my original system? Cause there is a lot of photo and video still in there. | |
11-26-2016, 06:03 | #2 (permalink) |
No Life Poster Join Date: Sep 2010 Location: KERALA,INDIA
Member: 1392433 Status: Offline Sonork: 100.1650669 Thanks Meter: 90 | ================================================== ======== Phone Type : Lumia 1020 CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Procedure : WP8 FFU Flasher via JTAG ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501004D424734574107D29E4A2C8012 Flash Description: Samsung MBG4WA, 29.12 GiB, SN D29E4A2C, Aug 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (6024 Op/Sec) Erasing "USER" area, flash #1, p#0, 0x0000000000, 0x0747C00000...OK Loading AFP (Please Wait)...OK AFP revision 4, compiled 25/06/2014 11:55:00 p.m. ================================================== ======== Phone Type : Lumia 1020 RM-875 CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Boot Package: 3051.40000.1345.1012 (BIG BOOT) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501004D424734574107D29E4A2C8012 Flash Description: Samsung MBG4WA, 29.12 GiB, SN D29E4A2C, Aug 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (6024 Op/Sec) Restoring MBR Data...OK Restoring GPT Data from AFP...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...OK Completed in 0h 11m 56s. Code Download Speed 244 KiB/sec. Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== Make sure you are using ATF JTAG v1.0.11 or Higher versions... Download FFU_FLASHER.afp for your phone model via ATFJ.exe built-in downloader "Help" ----> "Updates" http://forum.gsmhosting.com/vbb/f609...added-1660094/ |
01-08-2017, 11:02 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | Dear support; Where can i find TP picture for Lumia 1020 RM-875?by the way i do not know the phone product code and i can't find it on the package.I have imei number and it is 357254055478343 |
