Member: 64823
Thanks Meter: 439 | Lumia 520 - Jtag - Erased and Write ! I have Erase and then flash ... But after on stuck on FLIGHT MODE !
here is LOG: Quote:
Default language ID 0x0409, LR 12
JTAG Interface Connected, S/N 0x910025A8
Resetting and Exploring JTAG chain...No Devices found in Chain!
Loading AFP (Please Wait)...OK
AFP revision 4, compiled 9/3/2014 2:26:00 PM
Phone Type : Lumia 520, 520T, 525, 526
CPU Type : Qualcomm MSM8227
Storage Type: eMMC 8GB
Procedure : WP8 FFU Flasher via JTAG
More Info : <<<<<<<< ATF JTAG Lumia WP8 FFU Flashing Procedure >>>>>>>> - GSM-Forum
1. Make sure JTAG Connection is 100% OK
2. Always Disconnect the Phone BATTERY
3. Connect USB Cable to Phone
4. Connect RJ-45 JTAG Cable to ATF Box
5. Select the Correct Phone Type RM-XXX
6. Use RESET JTAG button to check the JTAG Connection
7. Click RESTORE BOOT button to Start Boot Repairs
Resetting and Exploring JTAG chain...1 Device(s)
Device #1 ID 0x4F1F0F0F IR4
Waiting for Device Connection 15 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core...OK
Initializing Device...OK
Detecting eMMC #1 ID...1501004D3847325943003F44B69E3152
Flash Description: Samsung M8G2YC, 7.28 GiB, SN 3F44B69E, Mar 1998
Partition Config: Boot from USER, Boot ACK OFF (0x38)
Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00)
Testing Device Memory...OK
Sending Flash Loader...OK (5954 Op/Sec)
FFU File Loaded: RM914_3058.51000.1523.1010_RETAIL_apac_australia_n ew_zealand_295_10_482764_prd_signed.ffu
FFU File CRC-32: Computing, Please wait...0xBF0E80EE
Analyzing FFU, please wait...OK
Restoring MBR Data...OK
Restoring GPT Data from Backup...Flash Write Error at 0x00000200, Loader Error, Code 0x71
Halting Core...OK
Sending Flash Loader...OK (5953 Op/Sec)
Erasing "USER" area, flash #1, p#0, 0x0000000000, 0x01D2000000...OK
Halting Core...OK
Restoring GPT Data from Backup...OK
Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...OK
Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...OK
Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...OK
Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...OK
Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...OK
Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...OK
Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...OK
Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x0000264000...OK
Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x000098C400...OK
Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004BC8000...OK
Completed in 0h 6m 21s. Code Download Speed 258 KiB/sec.
