07-01-2013, 13:35 | #1 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: GREECE
Member: 755804 Status: Offline Thanks Meter: 91 | Lumia 610 Boot Repair - [SOLVED] Quote:
07-01-2013, 13:39 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @bfc_xxx Solder wires to contacts and repair boot again. TP cable have problem. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
07-03-2013, 08:18 | #3 (permalink) | ||
Member: 755804 Status: Offline Thanks Meter: 91 | I repaired boot by soldering wires: Quote:
Also I see when phone is connected to USB boots I see some logos and then restarts all the time. Last edited by bfc_xxx; 07-03-2013 at 08:23. | ||
The Following User Says Thank You to bfc_xxx For This Useful Post: |
07-03-2013, 18:34 | #6 (permalink) |
Member: 755804 Status: Offline Thanks Meter: 91 | I've tried that and a couple of different batteries but the problem persist. Is it possible it is same problem as described here: http://forum.gsmhosting.com/vbb/f609/solution-lumia-710-800-800c-not-flashing-after-tp-boot-repair-1673102/ But I think Lumia 610 is not OSBL QCOM. |
07-04-2013, 12:38 | #7 (permalink) | |
Member: 755804 Status: Offline Thanks Meter: 91 | It seems afterall it was battery problem. The battery connectors on pcb was broken. I fixed that and then phone flashed normally. @srinibas you were right. Many thanx ATF team. Quote:
