Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-16-2012, 11:08   #1 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,509
Lumia 800 Unlock Problem
Lumia Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
Reading Platform Information...
Selecting Active Handle...
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 800/800C Detected
Storage Device Information
Manufacturer ID: 11
Application ID : 0100
Product Name : 016G4B
Product Rev : 00
Product SN : D688A728
Protection Information
Write Protect A: OFF
Write Protect B: OFF
Dumping AMSS FAT16 Region
Please wait for 2-4 Mintues...
ERROR: Dump Aborted, Too much CRC Failures!
Total Elapsed Time 00:00:02
What to do ?
The Following 2 Users Say Thank You to nasirahmed For This Useful Post:
Old 09-16-2012, 16:55   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,352
Flash the phone with AMSS file only & try to unlock .
Br - srinibas
Old 09-16-2012, 18:39   #3 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,509
flashed with several firmware versions, changed pc,,,,,, same always.
P.S. - If I repair boot, its done smoothly, but when I click SP Unlock... shows this error.
Old 09-16-2012, 19:24   #4 (permalink)
Cheater -Don't Deal with him-
Member: 686535
Sonork: 1592667
Thanks Meter: 108
some probleme with me
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 00
Application ID : 0000
Product Name :
Product Rev : 00
Product SN : 09C40000
Old 09-16-2012, 19:26   #5 (permalink)
Member: 686535
Sonork: 1592667
Thanks Meter: 108
mr nasirahmed
send me amss file here if u can for test
thx
Old 09-16-2012, 19:34   #6 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,509
you have navifirm .
Old 09-16-2012, 19:37   #7 (permalink)
Member: 686535
Sonork: 1592667
Thanks Meter: 108
but i cant found rm 801 i found only rm-819
Old 09-17-2012, 10:25   #8 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Hi,
It available in Navfirm+ 1.7 - Nokia 800 (RM-801)
Old 09-17-2012, 15:55   #9 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
Thanks Meter: 183
so what about error !!!
same here........
PHP Code:
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 11
Product Rev    : 00
Product SN     : 4D082F60
Total Elapsed Time 00:00:11
Old 09-17-2012, 17:37   #10 (permalink)
Member: 337306
Thanks Meter: 10
some problem ================================================== ====
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 11
Product Rev : 00
Product SN : 148B2885
Total Elapsed Time 00:00:03
Old 09-18-2012, 01:09   #11 (permalink)
multimedia box's Avatar
Member: 49263
Sonork: 100.92840
Thanks Meter: 309
Angry same error after flash AMSS
here my log:
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 11
Product Rev : 00
Product SN : CAC9A92F
Does the Version is the reason mine is
1600.2487.8107.12070
product: 059N8H9
RM-801.
Old 09-18-2012, 09:16   #12 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,509
I was able to unlock the phone. As I told before, I could repair boot without any problem, I flashed QUALCOMM DLOAD. Now in OSBL mode phone got qualcomm driver and NAND Disk Drive. I unlocked with other tool with USB.
Old 09-18-2012, 10:20   #13 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 119
which tool did u use for unlock with usb please help with guide i have one for unlock
Old 09-18-2012, 12:09   #14 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,509
NSS Pro, MX BOx can unlock lumia 710 & 800 if bootoader is unlocked.
Old 09-18-2012, 12:53   #15 (permalink)
Member: 337306
Thanks Meter: 10
how unlock bootloader. pls post solution for unlock bootloader
Page generated in 0.18976 seconds with 8 queries
