01-22-2014, 14:14 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Lumia 920 Locked again after many months Now after many months, customer returned phone asking for code. I put the same old code and its not accepting. What do I do next ? |
01-22-2014, 15:56 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, customer must have updated the phone and why old code isn't working could be because AT&T gave you PUK code and you are maybe writing code on PIN request... If this is the case, than use all 10 PIN request and after phone should ask for the PUK code - now you should write the old-codes. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
01-23-2014, 10:39 | #4 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @german gsm team: I thought it is Lumia 900 WP7, my bad... @dannyogolo: Lumia 920 WP8 doesn't have PUK request or anything like SIMLock counters. They will get back to 10 left every time we restart the phone. So, for your problem - check if the codes you are writing is for same IMEI as the phone. BR |
01-25-2014, 08:45 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | WP8 Lumia does not have PUK... Unlock attempts are unlimited but with delays. 20-digit unlock code is saved in a fat16 file "unlock.bin" similar to PM 120-3... This file does not get erased even when you flash phone. It gets invalidated when carrier releases updates to "disable" unlock. Try to downgrade phone with low version, it should accept the code again... that is if nothing is wrong with the code. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
01-25-2014, 08:46 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Just keep in mind... downgrading might kill phone or it might not... WP8 is tricky like this... in other words "unstable" |
