10-22-2014, 16:56 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | lumia showing QUALCOMM MSM DEVICE, how to change it for flashing? that drives as "QUALCOMM MSM DEVICE", Please what does it mean and how will I solve it to be able to flash the phones? Thanks! |
10-22-2014, 23:14 | #3 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1863004 Status: Offline Thanks Meter: 11 | Sorry don't have privileges to post link but input "710 qualcomm msm driver" into forum search box and look for post dated 27/03/14 by GSMWorld; this driver not required to flash and need to remove if it has already been installed upon PC. |
10-23-2014, 01:28 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @lionfinger2007 Look at Device Manager and check VID/PID of USB device. You will see it in Properties --> Details --> Hardware Ids. It should be something like USB\VID_05C6&PID_???? The PID Value is important to know... So we will know how to solve your problem. First, try to Charge the 720 Battery externally using external charger. If your 720 is really dead, then it will not charge battery at all. Once you give correct PID for both 710 and 720, then we can suggest solution. |
10-23-2014, 10:13 | #5 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
Here are what I saw on the both, please help me out; 720 = USB\VID_045E&PID_062A&REV_0000 USB\VID_045E&PID_062A 710 = USB\VID_05C6&PID_9006&REV_0000&MI_00 USB\VID_05C6&PID_9006&MI_00 | |
10-23-2014, 10:42 | #6 (permalink) | |
Freak Poster Join Date: Nov 2003 Location: inside Age: 43
Member: 44240 Status: Offline Thanks Meter: 12 | Quote:
Trick to change bootloader in all lumia phone I found this usefull trick : MangoTech: How to Restore Dload Bootloader from Qualcomm Bootloader on Nokia Lumia 710.. first ever tutorial!!! it's works for almost lumia phone 610-710-800 and it's very good if you can't open phone but you need to change bootloader from qualcomm boot to dload boot. if link don't work search my old post | |
The Following User Says Thank You to warriors For This Useful Post: |
10-23-2014, 17:51 | #7 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
720 USB\VID_045E&PID_062A&REV_0000 This means phone is LOW BATTERY and it is Charging the Battery. Try to charge it first for few hours via WALL Charger. If it still cannot POWER UP, open phone and check voltage of Battery +/- when it is disconnected form the phone's PCB. You can either repair boot via eMMC TP (FREE NO NEED ACTIVATION) or via ATF JTAG (NEED ACTIVATION) More Info you can find here: http://forum.gsmhosting.com/vbb/f609...830-a-1830880/ 710 VID_05C6&PID_9006 Is your phone detected as a new HDD Drive? If it is not detected as a HDD Drive, then phone is probably BOOT dead and you need to repair boot via eMMC TP. | |
10-23-2014, 18:53 | #8 (permalink) | |
You mean here MangoTech: How to Restore Dload Bootloader from Qualcomm Bootloader on Nokia Lumia 710.. first ever tutorial!!! | |
10-24-2014, 01:17 | #9 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | In ATF eMMC Direct tab in Windows Phone section, there is a button labeled "RESTORE DLOAD" which does what that tutorial says in 1 click. This only works if phone is detected as a mass storage device (HDD). |
10-24-2014, 16:24 | #10 (permalink) | |
For 710 (RM-803) when I connect it, it will prompt "You need to format the disk in drive F:before you can use it. Do you want to format it?" Then if I checked DEVICE MANAGER, it detected as "Qualcomm HS-USB Diagnostics 9006 (COM91)" under "Ports (COM & LPT)" If I go to the eMMC Direct, the "Restore DloaD" is not highlighted, Please how will I solve it? | |
11-05-2014, 16:22 | #12 (permalink) | |
Is like am missing some thing here. How will I make the atf software to have admin rights because I have right clicked and use "run as administrator" but when I scan, I found the log below but "restore dload" is not highlighting, am using window 7 ultimate 64 bit? the log; FOUND: Qualcomm MMC Storage USB Device Mounted Drive Number: 1 | |
