07-07-2012, 05:10 | #4 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
*** MAKE SURE ONLY ATF BOX IS CONNECTED ON THE USB PORT... *** If you connect other Boxes , then Your other boxes will HAVE *** PROBLEMS 1. Force Update the drivers for USB Serial Converter A using the Drivers from Step 1. 2. Force Update the drivers for USB Serial Converter B using the Drivers from Step 1. 3. Restart your PC if it asks you to restart... 4. Run MPROG and Write this EEPROM File to your ATF Box: new abox turboflasher.ept *** MAKE SURE ONLY ATF BOX IS CONNECTED ON THE USB PORT... *** If you connect other Boxes when writing the EEPROM, then *** Your other boxes will HAVE PROBLEMS 5. After Writing the EEPROM to your ATF Box, Disconnect The ATF Box from the USB Port, then reconnect it. It will now ask for drivers... 6. Use the correct drivers from: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\ Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
07-07-2012, 05:55 | #5 (permalink) | |
Freak Poster Join Date: Aug 2010 Age: 39
Member: 1379824 Status: Offline Thanks Meter: 26 | Quote:
07-07-2012, 06:00 | #6 (permalink) |
No Life Poster Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | *** MAKE SURE ONLY ATF BOX IS CONNECTED ON THE USB PORT... *** If you connect other Boxes when writing the EEPROM, then *** Your other boxes will HAVE PROBLEMS 5. After Writing the EEPROM to your ATF Box, Disconnect The ATF Box from the USB Port, then reconnect it. It will now ask for drivers... 6. Use the correct drivers from: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\ and update ............... |
The Following User Says Thank You to haji rahim For This Useful Post: |
07-07-2012, 11:43 | #7 (permalink) | |
Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 10.3.12 Software Version : v8.95 AdvanceBox SN : CC8191CEF4716627ACDAC53E Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done but after bus check fail Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED | |
07-07-2012, 11:47 | #8 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @arjun-kumar Install NEW ATF Drivers from v8.90 setup, inside ROOT folder. After Restore Box from Product Support tab, and try to BOOT any BB5 via FBUS. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
