07-30-2011, 07:35 | #2 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1527186 Status: Offline Thanks Meter: 1 | Hi bro first u check ur box registerd or not if not then registerd then not booting anyphone now so u registrd ur box after ur prblm is solve if u already registred then contact with ur resaller br. jay |
07-30-2011, 11:26 | #5 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Buy Buy Thank U GsmHostig .... Age: 41
Member: 462292 Status: Offline Thanks Meter: 397 | same problem bro even i check with working phone mobile not go in test or local mode. Forcing Test Mode via BUSCHECK... VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... BootFlashModeDCT5Ex Failed ERROR : PHONE READ INFO FAILED Use "BUSCHECK" Button to Force the Phone into Local Mode... Then "SCANPHONE" after. For N95, N95-8GB and E90 Phones, you need a Test Mode Adapter to provide some Extra Power so that the Phone will go into Local Mode... |
07-30-2011, 14:32 | #8 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | only blue light can i solve this software or use this method http://forum.gsmhosting.com/vbb/f609...dware-1318621/ ? |
07-31-2011, 00:19 | #10 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Great India
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | BRO. u must need yr box pcb modified. i face same problem before. my box pcb modified after working very well without any problem. |
07-31-2011, 10:54 | #11 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
08-01-2011, 08:17 | #12 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | 100000000000000% working by this method http://forum.gsmhosting.com/vbb/f609...dware-1318621/ Uploaded with ImageShack.us |
09-06-2011, 08:37 | #13 (permalink) |
Member: 462292 Status: Offline Thanks Meter: 397 | After do this i get 70% of bb5 pic get this error lashing Speed: 15.00 Mhz Processing : rm635__10.65.mcusw Total blocks to write : 1165 ================================================ FBUS Cable RX2 PIN Diagnostics ================================================ Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5 Block Length : 0F BB ASIC Index : 00 Error Type : 05 Error Spec : 08 Of*****ng Address : 00000400 Expected Content : 00009D3D Detected Content : 00009D00 Reconnect your Cable Properly because RX2 PIN is NOT getting any DATA from the Box!!! ================================================ ERROR: RX2 PIN is NOT CONNECTED PROPERLY !!! ================================================ Flashing FAILED BB5_WRITE_FlashFile_0 Go to Settings --> Nokia Settings --> FBUS DDR&2TX Synchronization Timeout Change the current value selected to a higher value and Restart AdvanceBox.exe software to apply it Operations Failed.... i try with select higher value but same .. cable is ok bec i flashing with same cable in my another atf . |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
