Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-16-2012, 07:43   #1 (permalink)
Member: 1712884
Thanks Meter: 857
Exclamation my atf flasher not flash dct4
           Advance Turbo Flasher Found
Driver Version       : 00020824
Library Version      : 00030207
Box Type               : ATF Nitro
Box Firmware        : LogiCore 10.3.12
Software Version  : v8.95
AdvanceBox SN    : B27F0947F5862D0C8479A70F
Box Status            : ACTIVATED
          Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up   >>>>
SET VCCIO Level Done
SET BSI Load Done
             Basic Phone Information
MCU Version: V 5.11 30-05-06 RH-73 (c) Nokia.
IMEI Plain : 353267013066624
IMEI Spare : A353267013066620
IMEI SV    : 33532670130666210F
Phone Model: Nokia 6060
Category   : Classic Phone
Phone Type : RH-73
            Extended Phone Information
Product Serial Number: DPA063172
Product Code         : 0526686
Module Code          : 0202716
Basic Production Code: 0523462
PPM SW Version       : V 5.11 30-05-06 RH-73_74 (c) Nokia. G
MCU SW Version       : V 5.11 30-05-06 RH-73 (c) Nokia.
HW Version           : 0541
UEM Version          : 1328
UPP Version          : 8241
RFIC Version         : 0500
DSP Version          : P05w19.v25.1.1
LCD Version          : SUEZ
               Simlock Information
CONFIG KEY    :  8C030008070028FF
PROVIDER KEY  :  0040000005FFFFFF
NETWORK NAME  :  Unknown Provider
LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
SIMLOCK TABLE :
SIMLOCK STATE :  Not Locked
SIMLOCK_TYPE             : UNKNOWN
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
PHONE_MODE              : LOCAL
Make sure you have installed the
COMPLETE Flash Package for this Phone...
Goto "Settings" --> "Nokia Settings" and verify that
the Folder where you installed your Flash Files are
in the "PRODUCT PATH TO SCAN" List...
after flash:
ImageFile:D:\NOKIA\dct4(2)\6060.RH-73\5.11(farsi)\rh73_74__5.110
PhoneType : DCT4
Algorithm : DCT4 ALGORITHM
Supported Hardwares :
                         > 1131
                         > 1130
                         > 2140
                         > 2141
                         > 2142
                         > 2143
                         > 2031
Secondary Sending Speed    :  100000Hz
Algorithm Sending Speed    :  6500000Hz
Program Sending Speed      :  6500000Hz
Message Reading Speed      :  51000Hz
Number of Blocks :  476
Entry Point:  0x00E2
Is128k:   True
Boot Check, Please wait...
DCT4 Failed to BOOT
DCT4 Failed to BOOT
DCT4 Failed to BOOT
DCT4 Failed to BOOT
Flashing FAILED...
Flashing ERROR
Old 07-16-2012, 08:36   #2 (permalink)
fortunemobile's Avatar
Member: 1728389
Sonork: 100.1617627
Thanks Meter: 57
SET BSI Load Done
Phone Type : RH-73
HW Version           : 0541
UEM Version          : 1328
UPP Version          : 8241
RFIC Version         : 0500
LCD Version          : SUEZ
               Simlock Information
SIMLOCK TABLE :
PHONE_MODE              : LOCAL
after flash:
PhoneType : DCT4
                         > 1131
                         > 1130
                         > 2140
                         > 2141
                         > 2142
                         > 2143
                         > 2031
Entry Point:  0x00E2
Is128k:   True
DCT4 Failed to BOOT
DCT4 Failed to BOOT
DCT4 Failed to BOOT
DCT4 Failed to BOOT
Flashing FAILED...
Flashing ERROR
bro check your cable connection
The Following User Says Thank You to fortunemobile For This Useful Post:
Old 07-16-2012, 08:57   #3 (permalink)
Member: 1712884
Thanks Meter: 857
tnks :
other model wery good flashing but only dct4 not flashing!!!
my box wery good AND ESY flashing model:
BB5 AND INFENEON BYE FBUS:
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.20076 seconds with 9 queries
