Member: 244558
Thanks Meter: 85 | My atf is not good for flashing <<< ANSWERED >>> HELLO REAPECTED TEAM MEMBERS,
I AM USING ATF BOX BECOZ OF ITS TOO MUCH GOOD FEATURES, BUT I AM VERY DEPRESSED BECOZ OF ITS FLASHING PROBLEM , MY FIRST CHOICE IS ATF FOR REPAIRING NOKIA MOBILES , BUT ALWAYS MY HOPES GETS BURRIED IN PIT, WHEN IT NOT PERFORMS UPTO MY EXPECTATION,
WHENEVER I TRIED TO FLASH NOKIA PHONES WITH IT , IT ALWAYS GIVES ERROR AND NOT PERFORM ANY OPERATION, BUT SAME THING WHEN I TRIED WITH MX-BOX AND INFINITY BEST DONGLE, THEY WORKS FINE , THE CABLES ARE GOOD, FLASH FILES ARE GOOD, BOX DRIVERS ARE UPTO DATED , SO WHERE IS THE PROBLEM , HERE IS THE LOG AND PICTURES OF THE PROBLEM GIVEN BELOW
NOKIA 2700 (RM-561) LOG WITH ATF Quote:
ATF Software Version v8.60
ATF Box FBUS Flash Started...
Number of Image Files: 3
Processing Image File :
C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 6500000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 1256
Entry Point : 0x5047
Page Format : 128K
Maximum Page Size : 0x00004000
Changing MODE : FLASH
Booting Phone via FBUS...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 24D0010F
ID DWORD 1 : 886D0156
ID DWORD 2 : 369CDEB5
ID DWORD 3 : 550E62DA
ID DWORD 4 : E4598B7A
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 0F
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version 010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : 03
SubBlocks : 03
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0089 ->
Device ID : 8982 -> NU48F512
Extended/Fixed ID : 0000
Revision ID : 8A31
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : 51
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
Flash Descriptor
Device ID : 8982
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version 010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
3EA22A1DDA660002E56108DB5072A10F8709443F
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x36 (54)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:43
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing : rm561__09.98.mcusw
Total blocks to write : 1256
FBUS Cable RX2 PIN Diagnostics
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
Block Length : 01
BB ASIC Index : 00
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:58
C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_mh
CMT Type : BB5
Number of Blocks : 399
Entry Point : 0x00B6
Page Format : 128K
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01520000-01DBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:00:32
Processing : rm561__09.98.ppm_mh
Total blocks to write : 399
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:17
C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.image_mh_gray
CMT Type :
CMT Algorithm :
Secondary Sending Speed : 0 Hz
Algorithm Sending Speed : 0 Hz
Program Sending Speed : 0 Hz
Message Reading Speed : 0 Hz
Number of Blocks : 0
Page Format : 128K
Operations Failed....
| HERE THE LOG WITH MX-BOX WITH SAME FILES AND SET GETS ON WITH THIS Quote:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0853BB0
Using device: HTI, FW ver: 00.50, SN: 0000369B
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 24D0010F886D0156369CDEB5550E62DAE4598B7A
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
TransmissionMode: DDR&TX2
Processing MCU file: rm561__09.98.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0137FFFF]
CMT FLASH,NOR area [01380000-0151FFFF]
erased in 1 min 48.373 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 31.760 s
Processing PPM file: rm561__09.98.ppm_mh
[BB5,BB5 ALGORITHM] size: 6.23 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF]
erased in 33.462 s
NOR: OK
NOR: OK
Programming completed in 28.267 s
Processing CNT file: rm561__09.98.image_mh_gray_128
[BB5,BB5 ALGORITHM] page size: 128 K size: 7.95 MB
UCP page size is 128 K.
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF]
CMT FLASH,NOR area [02160000-03FBFFFF]
erased in 3 min 49.523 s
NOR: OK
NOR: OK
Programming completed in 35.583 s
Total time for flashing process(boot+erase+write) was 8 min 55.519 s
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35430104*****
Product code: 0587992
Battery voltage: 4720 mV, current: 97 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NIMMIIIIRRFF094B2F01, ver: 002.014
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35430104*****
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 3.441 s
| here is the images
with atf
with mx-box
same problem with usb flashing, here is the log of nokia 3110c
with atf
with infinity best
please help me , to solve this problem, |
