01-18-2016, 18:38 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: lahore
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | my n9005 is stell dead. here is logs. ========================== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D4247344743009718608DB0D5 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 31268536320 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : MBG4GC Product Rev : 0.0 Product SN : 9718608D Manufactured : November 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D4247344743009718608DB0D5.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: PIT Start Writing 0x00000009 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x03A3DFDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: aboot.mbn Start Writing 0x00001000 Blocks at 0x00026800 Partition Selected: USER AREA Total Elapsed Time 00:00:04 Write Success! Flash Image: sbl1.mbn Start Writing 0x00000400 Blocks at 0x00026380 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: rpm.mbn Start Writing 0x00000400 Blocks at 0x00027800 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: tz.mbn Start Writing 0x00000400 Blocks at 0x00027C00 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: sdi.mbn Start Writing 0x00000040 Blocks at 0x00026780 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: non-hlos.bin Start Writing 0x00007800 Blocks at 0x00002000 Partition Selected: USER AREA Total Elapsed Time 00:00:26 Write Success! Total Images Written: 6 Process Done! |
