09-20-2014, 14:59 | #1 (permalink) |
Registered User Join Date: Feb 2008 Location: Turkey
Member: 706054 Status: Offline Thanks Meter: 30 | N7100 mmc convert 9300 İme null plss help 1:advance toll open 2:mmc toll open 3:normal factory erase 4:smsung erase 5:wİrte ext cds 6:wrİte İ9300 user fİle 7:wrİte bot 1 8:wrİte bot 2 but open phone İme nuull how to solve proplem |
09-20-2014, 15:21 | #2 (permalink) | |
Member: 706054 Status: Offline Thanks Meter: 30 | Quote:
3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010056545530304D0882AD8802 CSD : D02701320F5903FFF6DBFFFF8E40406D eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15634268160 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VTU00M Product Rev : 0.8 Product SN : 82AD8802 Manufactured : January 1998 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010056545530304D0882AD8802_E0B8CDFA.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Write EXT_CSD Backup Task Done! Start Writing 0x001EC209 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:27:36 Write Success! Start Writing 0x00001000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:05 Write Success! Start Writing 0x00001000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:04 Write Success! eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15634268160 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VTU00M Product Rev : 0.8 Product SN : 82AD8802 Manufactured : January 1998 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010056545530304D0882AD8802_743D80B7.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ | |
