09-16-2013, 08:19 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: P A K I S T A N
Member: 1252644 Status: Offline Sonork: 100.1602567 Thanks Meter: 47 | N9 flashing failed LOGS Number of Image Files: 2 (Mass Memory File Detected) Processing Image File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO Processing Image File : DFL61_HARMATTAN_40.2012.13-7.MEA_EMMC_MEA.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin I:\products backup\rm-696\ C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin -F DFL61_HARMATTAN_40.2012.13-7.MEA_EMMC_MEA.bin I:\products backup\rm-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw Processing Image: cmt-2nd Processing Image: cmt-algo Processing Image: cmt-mcusw Processing Image: xloader Processing Image: secondary Processing Image: kernel Processing Image: rootfs ERROR: MEEGO Device Flashing Failed! Booting/Flashing Failed... Please Try Again... |
09-16-2013, 10:02 | #4 (permalink) | |
Member: 1252644 Status: Offline Sonork: 100.1602567 Thanks Meter: 47 | Quote: logo before i flash it now it shows a triangle mark and says that "your warranty is permanently void bla bla" nothing else | |
09-16-2013, 10:22 | #5 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | The error not from ATF , it due to phone . You can try with a good quality cable with full charged battery Br - srinibas |
