12-09-2016, 07:44 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: philippines
Member: 555850 Status: Offline Thanks Meter: 14 | N910g SDC HELP ================================================== ==== ================================================== ==== SDC UNBRICK Image Creator Version 3.0 ================================================== ==== ================================================== ==== Analyzing PIT Structure... Preparing RAW Values for Exynos... Analyzing Boot Structure... Mounting Virtual Disk... Checking Bootloader Files... Start Writing Partitions... Unmounting Virtual Disk... ERROR: SBOOT File NOT FOUND! SDC Unbrick Image Creation FAILED! Make sure your Flash Files have Bootloaders ive manage to make an sdc file from pit files that i have downloaded SM-N910G XSA pit (TRLTE_SEA_XSA.pit) SM-N910G ODD pit (TRLTE_SEA_XSA.pit) SM-N910 XSA pit (TRLTE_SEA_XSA.pit) my problem is i cant boot into bootloader using the sdc ive created i have also tried to create sdc files from diff BL from using the pit files above N910GDTS1BPC3_N910GODD1BOJ3_BNG N910GDTS1DPI2_N910GOLB1DPG1 N910GDTU1COL3_N910GXSA1COL3_XSA here is the logs ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x03 Application ID : SD Product Name : SS32G Product Revision : 8.0 Serial Number : E0374A58 Manufacture Date: August 2016 Card CID: 035344535333324780E0374A5801081B Card CSD: 400E00325B590000EDC87F800A4040C3 Card SCR: 0235800300000000 Card OCR: 00C0FF8000 SD Card Size : 31914983424 Bytes SD Block Size: 512 Bytes Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! Erasing SDC... Samsung SM-N910G UNBRICK Please Enter Android Version here (4.3, 4.4.2, 4.4.4 ???) Start Writing to SDC at 0x00000000... Number of Blocks: 0x00040000 Process Done... ================================================== ==== 1. Insert Micro SD Card to Phone 2. Make Sure Battery is Fully Charged 3. Press Volume Down + Home + Power Button 4. Flash the Phone with ODIN ================================================== ==== Total Elapsed Time 00:01:27 Write Success! when i insert the mmc and boot jig in the phone i only get a short vibrate after |
