Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-10-2015, 07:41   #1 (permalink)
Member: 2157664
Thanks Meter: 43
please help, I can't flash nokia 105 rm-908
Hello!
Whem I'm trying to flash nokia 105 rm-908 the flashing hangs like this:
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer ID: 0x00C2
Flash Chip Type: 64 Mbit (4Mb x 16) NOR
Extended Information: Multi-Bank / 1.8v
Processing Image File: D:\soft\firmware\nokia\products\RM-908\rm908_02.700
Data Block Found...
Number of Sections: 03
IMAGE Certificate Block Sent Successfully...
Processing Section 01 of 03
IMAGE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Please help!
Old 09-10-2015, 07:59   #2 (permalink)
Member: 2157664
Thanks Meter: 43
do I need to write flash through spi?
Old 09-10-2015, 20:43   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
No need SPI, you may try to flash with ATF old version, if the version you are using have some bugs.
Old 09-17-2015, 07:53   #4 (permalink)
Member: 702017
Thanks Meter: 2
which old version of ATF ?
regards
Page generated in 0.14953 seconds with 8 queries
