09-13-2013, 13:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Nitro box problem pls help me any one Code: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IndexOutOfRangeException: Index was outside the bounds of the array. at FT_Prog.FTDevice.SetStringDescriptor(String s, UInt16[]& dataToWrite, Int32& addrs, Int32 pointer, Boolean rdevice) at FT_Prog.FT2232H.DataEEPROM(FTDI d2xx) at FT_Prog.ScanDevice.ProgramDevice(FTDevice ft) at FT_Prog.programForm.btProgram_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll ---------------------------------------- FT_Prog Assembly Version: 2.6.8.0 Win32 Version: 2.6.8 CodeBase: file:///C:/Documents%20and%20Settings/JAI%20MATA%20DI/Desktop/FT_Prog%20v2.6.8/FT_Prog.exe ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- FTD2XX_NET Assembly Version: 1.0.10.0 Win32 Version: 1.0.10.0 CodeBase: file:///C:/Documents%20and%20Settings/JAI%20MATA%20DI/Desktop/FT_Prog%20v2.6.8/FTD2XX_NET.DLL ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- kt4hioig Assembly Version: 2.6.8.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. |
09-13-2013, 13:55 | #2 (permalink) |
No Life Poster Join Date: Jul 2008 Location: H.DALAA Age: 49
Member: 820444 Status: Offline Sonork: 100.1680641 Thanks Meter: 466 | what is the problem . post screen shot . witch led is on ? is pc not found box ? and see in device manager is atf installed. for more help give more problem decription |
