01-22-2013, 20:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: at work
Member: 112112 Status: Offline Sonork: 100.1621373 Thanks Meter: 238 | nokia 1800 read hash invalid file name <--- SOLUTION INSIDE or AUTO-UPDATE TO 9.51 >> VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** START INFINEON BUS CHECK ************************************************** **** Sending PBL 37888 bytes... PBL Successfully Sent... Unique Data: 4182D720058047813011 Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v unvalid file name what is the problem aft team |
The Following User Says Thank You to zeroualot_7 For This Useful Post: |
01-23-2013, 15:17 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @zeroualot_7 Auto Update your 9.50 to 9.51,, this will fix your problem... or Simply create this folder: C:\AdvanceBox Turbo Flasher\Nokia\SL3_Recovery\ This will fix your problem as well... |
The Following User Says Thank You to Advance-Box For This Useful Post: |
01-23-2013, 18:02 | #7 (permalink) |
No Life Poster Join Date: Mar 2008 Age: 39
Member: 738945 Status: Offline Thanks Meter: 58 | yes It's work 100% good job ATF team ================================================== Decrypting PM 120... PM 120 HASHES Extracted Successfully CA4DB6EAE7123C96FACE19E33B5BA3B174C4960A 57EA19B0A8DA448531EF57D76727927914A30F70 3452E99E23D377B2D69A493D47E3CE216ADF92F8 791BD33EB3582620505EA873E864134F412D0229 A50ADF876DB445E978CB6BABCDE1A81CADB2332C BA835374D2DD892EB0766CD48B7B3CC050B3720A 8DE377C9AC7023F550E61CD2CC5BF59F007BF5E6 623DF27133735D314F8FB9C10D14C7754C9B9199 Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\355369043209***\355369043 209***.job C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\355369043209***\355369043 209***.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\355369043209***\355369043 209***.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\355369043209***\355369043 209***.sha Command Line for ighashgpu: Saved as MS Batch File: 355369043209***_ighashgpu.bat Command Line for oclHashcat-lite64 (AMD Cards 64-Bit OS): Saved as MS Batch File: 355369043209***_AMD_oclHashcat_64-bit.bat Command Line for oclHashcat-lite32 (AMD Cards 32-Bit OS): Saved as MS Batch File: 355369043209***_AMD_oclHashcat_32-bit.bat Command Line for cudaHashcat-lite64 (NVIDIA Cards 64-Bit OS): Saved as MS Batch File: 355369043209***_NVIDIA_cudaHashcat_64-bit.bat Command Line for cudaHashcat-lite32 (NVIDIA Cards 32-Bit OS): Saved as MS Batch File: 355369043209***_NVIDIA_cudaHashcat_32-bit.bat Process Done! |
