Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-05-2014, 12:47   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
First In The World via ATF - Lumia 530 WinPhone 8.1 Full Flashing!
YOU NEED TO UPDATE TO ATF 11.70 BETA or HIGHER BEFORE FLASHING Lumia 530 and other WP 8.1 Phones.
Download ATF version 11.70 BETA EXE Here:
AdvanceBox.exe version 11.70 BETA <-------- Download and put in C:\AdvanceBox Turbo Flasher\
Also Download Nokia.ini Update here:
Nokia.ini <------- Download and put in C:\AdvanceBox Turbo Flasher\Nokia\
ATF First In The World Lumia 530 WinPhone 8 Full Flashing!
Also check out other Lumia WinPhone 8 Phones Flashed by ATF:
http://forum.gsmhosting.com/vbb/f609...shing-1680792/
http://forum.gsmhosting.com/vbb/f609...shing-1855707/
http://forum.gsmhosting.com/vbb/f609...shing-1680806/
http://forum.gsmhosting.com/vbb/f609...shing-1705355/
http://forum.gsmhosting.com/vbb/f609...shing-1821664/
http://forum.gsmhosting.com/vbb/f609...shing-1842436/
http://forum.gsmhosting.com/vbb/f609...shing-1680803/
http://forum.gsmhosting.com/vbb/f609...shing-1575683/
http://forum.gsmhosting.com/vbb/f609...shing-1576227/
http://forum.gsmhosting.com/vbb/f609...shing-1576622/
http://forum.gsmhosting.com/vbb/f609...shing-1573787/
http://forum.gsmhosting.com/vbb/f609...shing-1680813/
http://forum.gsmhosting.com/vbb/f609...shing-1689895/
http://forum.gsmhosting.com/vbb/f609...shing-1844241/
http://forum.gsmhosting.com/vbb/f609...shing-1727846/
http://forum.gsmhosting.com/vbb/f609...shing-1763465/
http://forum.gsmhosting.com/vbb/f609...shing-1746767/
You Can Download Flash Files Here:
http://forum.gsmhosting.com/vbb/f609...added-1660094/
Microsoft Lumia 530 WinPhone 8.1 Flashed Successfully with ATF 11.70 BETA...
Here are the Screenshot:
Here is the Flashing Logs:
Windows Phone 8/8.1 Flashing Started
Loading Flash Files Please Wait...
          Windows Phone 8/8.1 Lumia Flasher
If the Phone is ALIVE
  1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
  1. Connect Phone to the USB Port
  2. Press and Hold the VOLUME DOWN and POWER Buttons
  3. Wait until the Phone Vibrates Shortly...
  4. Stop Pressing the Buttons...
             Basic Phone Information
SW Version             : 01068.00023.14295.43001
IMEI Plain               : 353628061519063
IMEI2 Plain             : 353628061519071
Phone Type            : RM-1019
HW Version            : 5060
Product Code         : 059W448
Module Code          : 0206001
PSN Number           : CPP776374
Operator Name      : 000-CN
Phone Version        : BuildDate : Jul 14 2014 , BuildType : Release , HelloString : NCSd for WP8 , Version : 4.5
Manufacturer ID    : RM-1019_1027
Security Mode        : Restricted
            Extended Phone Information
Public ID              : DA2526085B0398C7C2D00ADF5FE65E6BCE179508
Wireless Lan 0 ID: D4:8F:33:25:4D:B4
Wireless Lan 1 ID: D4:8F:33:25:4D:B5
Wireless Lan 2 ID: D4:8F:33:25:4D:B6
Wireless Lan 3 ID: D4:8F:33:25:4D:B7
Bluetooth ID        : D4:8F:33:25:0A:A4
               Simlock Information
SIMLOCK STATE   : Not Locked
Booting Flash Mode Initiated...
Please wait upto 15 Seconds for HW Reset
Boot Flash Mode Successful...
Buffers Flushed OK...
Phone Info Query Start...
Blocks Returned: 0x09 Blocks
Block ID 0x01 : 00241000
Block ID 0x1F : 01
Block ID 0x02 : 00240000
Block ID 0x03 : 00760000
Block ID 0x05 : Nokia.MSM8212.P6134.1.1
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 01001F0000
Block ID 0x20 : 010000000100000004
Checking SD Card Size...
Card Size: 0x00000000
Checking Platform Security Status...
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Active
RDC Status: Not Active
Authentication Status: Not Active
UEFI Secure Boot Status: Active
Checking Secure FFU Mode...
Secure FFU Mode :
Query Flash App Information...
Flash App Information: 02021D023500
UEFI App: FLASH APP
Flash App Protocol Version: 2.29
Flash App Implementation Version: 2.53
Query ROOT KEY HASH...
ROOT_KEY_HASH: 6DF7F89E7A01F5B5DCB54754545B30B8B036C6BD294ACE42C8B34A7D504D6183
Sending Image Signatures...
Image Signatures Accepted!
Erasing Data Partition...
Data Partition Erased Successfully
Preparing Buffers for DATA LOOP...
Allocating System RAM OK!
Start Sending DATA BLOCKS...
Finished Sending all DATA BLOCKS!
Exiting FLASH Mode via REBOOT...
Exit FLASH Mode Successful!
Flashing Done!
Total Flashing Time : 00:06:01
Here is our Test Phone...
FLASHING The Phone...
BOOT Repair Tests will follow
X-Shadow
The Following 7 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-05-2014, 12:53   #2 (permalink)
Member: 170452
Thanks Meter: 24
Red face
hay good day how do you unlock???
Old 11-07-2014, 12:37   #3 (permalink)
Member: 1221964
Thanks Meter: 5
link is not work sir
The Following User Says Thank You to vijay raj For This Useful Post:
Old 11-07-2014, 17:06   #4 (permalink)
3STAR MOBILE's Avatar
Member: 1374790
Thanks Meter: 219
no connect 530
link not working...... Download ATF version 11.70 BETA EXE Here:
lumia 530 not connect..... not flash please help
ERROR: Active Phone Handle was NOT DETECTED
ERROR: Flashing Failed!
The Following User Says Thank You to 3STAR MOBILE For This Useful Post:
Old 01-16-2015, 00:10   #5 (permalink)
Member: 227878
Thanks Meter: 5
Where should I buy this box?
There are many ATF box, which one should I buy to unlock all Nokia Windows Phone, including Nokia Lumia 520, 530, etc...
Old 03-17-2015, 00:27   #6 (permalink)
Crazy Poster
Member: 2083000
Sonork: 100.1653938
Thanks Meter: 7
plz nokia lumia 610 windodws 8 not supported
Old 06-11-2015, 11:16   #7 (permalink)
Member: 1423806
Sonork: 100.1685119
Thanks Meter: 44
How must be the phone before flashing? ON / OFF? What to press in ATF? First it must be scanned the Phone?
It cannot detect my phone...
Old 07-24-2015, 08:28   #8 (permalink)
Member: 1349375
Thanks Meter: 8
Is this working for lumia 530 RM-1017, i want to flash my phone, any procedures?
thanks
Old 08-12-2015, 14:59   #9 (permalink)
Member: 1349375
Thanks Meter: 8
Can i use ATF to Flash Nokia Lumia 530 RM-1017 ?????
Old 08-22-2015, 18:09   #10 (permalink)
Member: 2364256
Sonork: 100.1676491
Thanks Meter: 15
Red face Sim
I want to unlock lumia 530 network
Old 09-01-2015, 11:32   #11 (permalink)
Member: 2452722
dead link.....................
Old 09-05-2015, 14:01   #12 (permalink)
Member: 1917268
how to root my samsung galaxy Gt-I9300?
Old 11-28-2015, 16:24   #13 (permalink)
Maninder_111's Avatar
Member: 687144
Sonork: 1614780
Thanks Meter: 228
Old 03-13-2016, 14:13   #14 (permalink)
Member: 2059718
Sonork: Pradeephd3
Thanks Meter: 7
use less software ...................
Page generated in 0.22154 seconds with 8 queries
