03-30-2014, 07:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2013
Member: 1892312 Status: Offline Sonork: 100.1651296 Thanks Meter: 76 | nokia 5530 show phone start up failed contact the retailer i try to flash after flash. after flash nokia then white screen and power off |
03-30-2014, 10:11 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @Zubair45ali Phone start-up contact the retailer isn't related with flashing. Post here Scan Phone logs, so we check where is the problem and give you the solution. BR |
03-30-2014, 18:45 | #5 (permalink) | |
Member: 1892312 Status: Offline Sonork: 100.1651296 Thanks Meter: 76 | flash log.. with usb Quote:
Processing Image File : RM-504_40.0.003_prd.core.C00 CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 444 Entry Point: 0x2670AB Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-504_40.0.003_C01_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 23 Entry Point: 0x00D7 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-504_40.0.003_prd.rofs2.V11 CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 80 Entry Point: 0x00D7 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-504_32.0.007_007_000_U001.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 25 Entry Point: 0x00D1 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051105 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0FF00007 ID DWORD 1 : B5820052 ID DWORD 2 : 5F34D4A5 ID DWORD 3 : 0DA57507 ID DWORD 4 : 358B807D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : B8 C3 AD EC FC 99 7F CD 80 81 D3 DE AF 87 0B 8C 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_XSR15_a lg.fg SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) SendCodeStart_NewProtocol SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5 VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF START READING RPL DATA IMEI: 358253030316247 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... EMPTY NPC CERTIFICATE INFORMATION (CMT): IMEI : 358253030316247 PRODUCT CODE : 0577071 WLAN ID : A8:7E:33:6C:5D:20 BLUETOOTH ID : A8:7E:33:6C:4D:80 PUBLIC_ID : 0FF00007B58200525F34D4A50DA57507358B807D PAPUB_KEYS_HASH: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 0577071 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 0FF00007B58200525F34D4A50DA57507358B807D PRODUCT CODE : 0577071 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\358253030316247\3582530303162 47_110531.rpl ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-504\ ImageFilename: RM-504_40.0.003_prd.core.C00 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00080000 Size : 028E0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 02960000 Size : 07500000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 09E60000 Size : 058C0000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 0F8C0000 Size : 00160000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200080000028E0000000000040000000202960000075000 00000000080000000109E60000058C00000000000A00000001 0F8C000000160000A5 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x5F (95) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x2B (43) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00400000-007FFFFF 3 : 00800000-00D5FFFF 4 : 00D60000-09E5FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x00000000 Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000 ERASE_REQUEST_BB5 : 5005120B0003000004000000082FFF120B0003000008340000 3FFFFF120B00030000400000007FFFFF120B00030000800000 00D5FFFF120B00030000D6000009E5FFFFD5 FORMAT_REQUEST_BB5 : 5001192F00030000000000000000000000000A000000000000 00020000006400000003000000010000000100000000000000 003E Successfully Erased... Total blocks to write : 444 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [F2B05364E563A348608C1C3C9E54FE42AAAA1ACF] >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*ENO >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-504\ ImageFilename: RM-504_40.0.003_C01_prd.rofs3.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09360000-09E5FFFF ERASE_REQUEST_BB5 : 5001120B0003000936000009E5FFFFB3 Successfully Erased... Total blocks to write : 23 >> CMT Rootkey Hash CERT : SOS+ROFS3 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-504\ ImageFilename: RM-504_40.0.003_prd.rofs2.V11 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 07360000-0935FFFF ERASE_REQUEST_BB5 : 5001120B000300073600000935FFFF65 Successfully Erased... Total blocks to write : 80 >> CMT Rootkey Hash CERT : SOS+ROFS2 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-504\ ImageFilename: RM-504_32.0.007_007_000_U001.uda.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09E60000-0F71FFFF ERASE_REQUEST_BB5 : 5001120B00030009E600000F71FFFF71 Successfully Erased... Total blocks to write : 25 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:02:27 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Operation Cancelled... Phone is not Connected OR it is not in the Required Mode... Reboot the Phone and Enable "PC Suite" Mode Operation Cancelled... | |
