02-16-2012, 10:15 | #1 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1350924 Status: Offline Sonork: 100.1613496 Thanks Meter: 13 | ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ************************************************ INIT : FAILED , CHECK YOUR BOX FIRMWARE ************************************************ When press restore box get this Advance-Box Secure AES-128 Channel Open Port Success... Error return code 6 Error return code Elapsed time = 00:00:00 |
02-18-2012, 12:51 | #3 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
i also have the same problem,,even i posted flashing log but no responce then i left asking for support. http://forum.gsmhosting.com/vbb/8137597-post5.html even this fone got alive from other flashing tool BR Last edited by mobile_hotman; 02-18-2012 at 12:58. | |
02-23-2012, 20:24 | #6 (permalink) |
No Life Poster Join Date: Apr 2010 Location: lagos nigeria
Member: 1278793 Status: Offline Thanks Meter: 68 | atf answer a lot of us are facing this same problem i just got my box 5days ago but i can't use it since then when i press restore box it shows server error |
02-25-2012, 10:48 | #7 (permalink) |
Member: 1350924 Status: Offline Sonork: 100.1613496 Thanks Meter: 13 | Any one can describe this error When press restore box get this Advance-Box Secure AES-128 Channel Open Port Success... Error return code 6 Error return code Elapsed time = 00:00:00 |
02-25-2012, 16:09 | #8 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | Strange no body is helping mothsd. Connect atf directly to PC. check PC bios if usb port are set to usb2.0 mode and latest PC drivers are installed. use latest ATF drivers from atf folder. connect only ATF to PC, specially don't connect with UB connected. |
02-25-2012, 17:58 | #9 (permalink) | |
Member: 1350924 Status: Offline Sonork: 100.1613496 Thanks Meter: 13 | Hi Quote:
I have connect nokia chager on the gpg cable ( A TO B Cable).. the problem was gone.. | |
02-27-2012, 06:40 | #12 (permalink) |
Member: 153805 Status: Offline Thanks Meter: 325 | Don't connect nokia charger as its output is 6 to 8 volts approx. it may damage your box.instead of that use regulated 5v.also check your box by connecting it to dc supply set at 5v ,how much current it consumes w/o phone attached.my box take less than 10ma.if your box draws more current ,than replace it if in warranty period or try to repair it. |
02-27-2012, 09:07 | #13 (permalink) | |
Its work fine with the charger output 5.7 volt.... | |
07-19-2012, 07:44 | #15 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Pakistan fr city kohat
Member: 1213187 Status: Offline Sonork: 1612770 g.raziq Thanks Meter: 157 | hi Any soultion ATF Box team ihave same to same problem ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ************************************************ INIT : FAILED , CHECK YOUR BOX FIRMWARE ************************************************ plz needed hlep mee on raziqbbr |
The Following 2 Users Say Thank You to raziqbbr For This Useful Post: |
