02-09-2015, 22:37 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | some questions 2. for convert or repair phone only boot 1 and boot 2 enough ? |
02-10-2015, 12:49 | #2 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,345 | Quote:
I9300 have his .Bin file for write and create ext csd file and N7100 have others. You can use one eMMc used of I9300 for replace in N7100 but first you have need or reprogram this one working, any eMMc have his partition that not are the same, also are both Exinos. This process of repartition first of use old one I9300 working in N7100, (also I9500), must need of to be reprogrammed with External adapter then can mount and now yes will be working. Anyway, N7100 thread, it's sticky, show all steps how do and eMMc file, for I9300 is the same thingh, change only the file used, (i've posted this for I9300 if you not have). BR allumts | |
02-10-2015, 12:56 | #3 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | ı have 100-150 emmc chip used need reprogram.. I dont know which n7100 which i9300.. I make reprogram Other ı have zero chip n7100 and i9300 ı want convert .. sample ı conect i9300 emmc first ı make ext csd backup after formats after ı make reprogram to convert n7100 after restore extcsd backup this prodecure right ? |
02-10-2015, 13:12 | #4 (permalink) | |
Remember that from wich version is single eMMc must need of do and write all 3 files or only 2 + ext csd, after you have reprogrammed right example for I9300 with No Error can solder in Phone. Help with this thread: http://forum.gsmhosting.com/vbb/f609...epair-1785442/ BR | |
