03-03-2014, 06:48 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Samsung N7100 - NO PRODUCT NAME REPAIR First of all repairing N7100 and I9300 eMMC is NOT A 100% SOLUTION!!! 80% of these problematic phones NEED eMMC Chip Replacement. This means you only have a 20% Success Rate on whatever Box or Tools you use. The eMMC Firmware of Samsung VTU00M have serious FLAWS and BUGS and after analyzing the said firmware deeper, I even found that it has a self-destruct sequence. It means that the eMMC has a built-in command to KILL ITSELF!!! I don't know if Samsung uses this "self-destruct" command and I AM NOT ACCUSING THEM that they use this command at all. I am just saying that it is there and I have confirmed that it is the ONE OF THE REASONS why the eMMC will loose Product name in CID[103:56] (This is not Product Name in BOOTLOADER... this is eMMC Product Name Only). So in SUMMARY: 1. YOU WILL NOT REPAIR ALL EMMC PROBLEMS FOR SURE. 2. IF YOU GET 10 BAD PHONES, YOU WILL MAYBE REPAIR ONLY 2 of THEM (More than 2 if you are Lucky). 3. EVEN AFTER YOU REPAIR THE EMMC, IT WILL DIE AGAIN AFTER A FEW DAYS, WEEKS, MONTHS etc... So without further delay, here are the Tools You need: 1. ATF Box + Binary Repair Files for N7100 Download Here: eMMC REPAIR FILES by d18.builder - 4shared 2. ATF eMMC Adapter (I used SmartGsm adapter) 3. 2 Pieces 100 ohms resistor 1/4 watts 4. Soldering Skills Step 1: Modify eMMC Adapter (add 100 ohms STRONG Pull-Ups) So here you will see that I added 2 resistors (100 ohms) to the CMD and the DATA0 of the eMMC Adapter. Both of the resistors act as a Strong PULL-UP to 3.3v. Step 2: Connect Wires to the eMMC on the PCB RED = CLK YELLOW = Secondary CLK (not needed if using eMMC Adapter) BLUE = CMD GREEN = DATA0 PINK = 2.80v Now here you will notice that both VccQ and Vcc are connected to 2.8V. The actual voltages used by the N7100 is 2.8v and 2.95v respectively, so 2.8V on both power sources should do just fine. Step 3: Connect eMMC Adapter to ATF Box and perform "Normal Factory Erase" What this does depends on the actual eMMC Specs version of the eMMC. It may erase USER AREA, BOOT1, BOOT2 and RPMB or it may just erase USER AREA and nothing else. Step 4: Perform "Samsung Factory Format" What this does also depends on actual eMMC Specs version... Check out the screenshot and logs to learn more. Step 5: Perform "Write EXT_CSD Backup File" Just write back the FIRST (Oldest) EXT_CSD Backup File for your eMMC. All EXT_CSD Backups are saved here: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Step 6: Perform "Write USER AREA" Just Follow Screenshot... Step 7: Perform "Write BOOT1" Just Follow Screenshot... Step 8: Final Checks Click "Scan eMMC" and make sure eMMC is set to BOOT PARTITION : BOOT PARTITION 1 You should see something like this: Code: eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB Now you can de-solder the wires and assemble the Phone to check the final results of your repair. If you get Problems/Errors in performing steps 1 to 8, then it PROBABLY means your eMMC is one of the 80% which needs replacement! B.R. Last edited by Advance-Box; 03-03-2014 at 07:50. |
The Following 27 Users Say Thank You to Advance-Box For This Useful Post: |
03-03-2014, 06:53 | #2 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Here is ONE of the phones I was able to repair... (We also have a lot of phones which required eMMC Chip replacement. After lemor changed the eMMC, the phone was fixed). Right After eMMC Repair Tasks were done... Phone Info showing 4.1.1... Download Mode showing Fixed "Product Name" I flashed phone to 4.3 just to check if flashing is OK B.R. |
The Following 26 Users Say Thank You to Advance-Box For This Useful Post: |
03-03-2014, 07:17 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: jamshedpur Age: 38
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | here is full firmware for n7100 for flashing after emmc repair . N7100XXDLJ2_OXA_FACTORY - Download - 4shared - Fashion House |
The Following 6 Users Say Thank You to lalitjsraks For This Useful Post: |
03-03-2014, 07:32 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | @Advance-Box, Really good info about emmc erase and Rebuild, today i will try this. BR, Srinivas Reddy. |
The Following 3 Users Say Thank You to swechacnu For This Useful Post: |
03-03-2014, 07:40 | #6 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL Here is HI-RES eMMC Pinout of N7100... http://174.120.45.27/tmp/N7100_TP_HIRES_EMMC_PINOUT.rar @Faheem Anjum Quote:
But as I said, there is no 100% solution. Most VTU00M eMMCs are really BAD. B.R. | |
The Following 10 Users Say Thank You to Advance-Box For This Useful Post: |
03-03-2014, 07:54 | #7 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
80% hardware issues in this chipset | |
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
03-03-2014, 08:01 | #9 (permalink) |
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | @ himanshu its same for i9300 too . emmc repair files here for both n7100 and i9300 . eMMC REPAIR FILES by d18.builder - 4shared |
The Following User Says Thank You to lalitjsraks For This Useful Post: |
03-03-2014, 08:05 | #10 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
why we spend money if this is possible For Free | |
The Following 3 Users Say Thank You to Faheem Anjum For This Useful Post: |
03-03-2014, 08:18 | #11 (permalink) |
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | @Advance-Box How can i find if emmc damaged or good, is there any solution without emmc erase or connect, why because some emmc after erase did not write boot files so it will dead, some customers giving stuck on logo without product name, so i am askuing about this. is there any perfect solution finding emmc bad or good. BR, Srinivas Reddy. |
The Following User Says Thank You to swechacnu For This Useful Post: |
03-03-2014, 08:20 | #12 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: pilapil marangle
Member: 1190283 Status: Offline Thanks Meter: 67 | Quote:
tnx........ atf boooommm | |
03-03-2014, 08:30 | #14 (permalink) | |
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | Quote:
here one more link with pit N7100XXDLJ2_OXA_FACTORY by c33t - 4shared | |
The Following 3 Users Say Thank You to lalitjsraks For This Useful Post: |
03-03-2014, 08:33 | #15 (permalink) | |
http://forum.gsmhosting.com/vbb/f609...nokia-1763485/ | |
The Following 2 Users Say Thank You to lalitjsraks For This Useful Post: |
