09-24-2014, 14:32 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | It means PIN #3 of your RJ45 should be connected on T + S both. Take out 2 cooper wires from PIN #3 and connect 1 to T and 2 to S. BR |
09-24-2014, 14:49 | #3 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Armenia
Member: 448264 Status: Offline Thanks Meter: 78 | Quote:
Resetting and Exploring JTAG chain...No Devices found in Chain! if connected to one only Initializing Device...Init Write Error at line 39, Shift IR Error(s) how repeirthis phone it's dead after flashing | |
09-24-2014, 15:36 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @juve2106 Remove battery and just connect USB cable. If you wire up everything correctly, then you will be able to repair it. If you make a mistake in wiring, then it will not work. Check many many many success logs in forum about this. There is nothing special to do. Just follow instructions and you will be OK. B.R. |
09-24-2014, 15:38 | #5 (permalink) | |
09-24-2014, 16:22 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @juve2106 Try this. 1. Do not connect USB cable to phone, connect only JTAG Wires to RJ-45 and connect to box. 2. Click "RESTORE BOOT", it will tell you something like "Waiting for connection..." 3. Connect USB cable, then post logs here if you still get problem. B.R. |
09-24-2014, 16:38 | #7 (permalink) | |
Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...No Devices found in Chain! | |
