NOKIA XL RM 1030 Flash Write Error at 0x00000200, Loader Error, Code 0x71 help me ATF team Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D42010A0DD47441B2 Flash Description: Samsung J5XWMB, 3.64 GiB, SN 0A0DD474, Apr 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91431 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x71 :(:(:( |
Is your Nokia XL v1 or v2? http://forum.gsmhosting.com/vbb/f609.../#post10893801 |
1. Download new EXE: ATFJ.exe 2. Download new .lng file and put this inside "\Lang\" Folder 0x0409.lng 3. Error should be fixed by this EXE. B.R. |
I had same problem,solved using same solution thank you x-shadow |
Please help: Nokia XL v1 ATF JTAG v1.0.15.8544 (17.06.2015) Default language ID 0x0419, LR 14 JTAG Interface Connected, S/N ______________ Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x____________ IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 28.09.2014 12:56:00 ================================================== ======== Phone Type : Nokia XL [RM-1030] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 1.1.0.6 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D42019B26D4B53147 Flash Description: Samsung J5XWMB, 3.64 GiB, SN 9B26D4B5, Mar 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91428 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! |
how to check xl firmware version??? Quote:
here is the info log Code: Basic Phone Information regards! |
Code: ATF JTAG v1.0.15.8544 (17.06.2015) |
http://i63.tinypic.com/2rd9u0p.png i have done boot repair before now after format my pc i can't make repair??? any solution. |
