02-26-2015, 13:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Nokia XL RM-1030 in Qualcomm HS-USB QDLoader 9008, after repair boot - (SOLVED) Code: Loading AFP (Please Wait)...OK AFP revision 4, compiled 28.09.2014 13:16:00 ========================================================== Phone Type : Nokia XL [RM-1030] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 1.2.3.2 ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...No Devices found in Chain! Restore Boot... Waiting for Device Connection 20 second(s)...Timeout During Operation! Restore Boot... Waiting for Device Connection 20 second(s)...Timeout During Operation! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x1077C0E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501004A3558574D4201FE7FDAB3611E Flash Description: Samsung J5XWMB, 3.64 GiB, SN FE7FDAB3, Jun 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91942 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...Flash Write Error at 0x000EBA00, DCC Read Error, Timeout During Operation! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x1077C0E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 39, Shift IR Error(s) Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501004A3558574D4201FE7FDAB3611E Flash Description: Samsung J5XWMB, 3.64 GiB, SN FE7FDAB3, Jun 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91940 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...Flash Write Error at 0x00005200, Bad Answer from Loader 0x0, 0x2A04 Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x1077C0E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501004A3558574D4201FE7FDAB3611E Flash Description: Samsung J5XWMB, 3.64 GiB, SN FE7FDAB3, Jun 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91918 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...Flash Write Error at 0x000D3A00, Bad Answer from Loader 0x0, 0x2104 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x1077C0E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501004A3558574D4201FE7FDAB3611E Flash Description: Samsung J5XWMB, 3.64 GiB, SN FE7FDAB3, Jun 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91941 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 1m 30s. Code Download Speed 229 KiB/sec. Boot Restore Done! ============================================================= Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure |
The Following User Says Thank You to Abzal For This Useful Post: |
02-27-2015, 13:52 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,119 | @Abzal SO it is V2 then... And your logs is showing you used V1 AFP file... SO download V2 AFP file and Fix the phone |
The Following User Says Thank You to Advance-Box For This Useful Post: |
02-28-2015, 02:22 | #5 (permalink) |
Junior Member Join Date: Oct 2008
Member: 883658 Status: Offline Sonork: 300488 Thanks Meter: 3 | some problem with me bos...my phone is showing qualcomm 9008 in device manager..and in back case show s/n 059v782....what version in this device ver 1 or ver 2 ? anyone have link full firmware (exe) for this phone?share please... sory for bad english bos...xixixixi |
02-28-2015, 03:25 | #6 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,119 | Quote:
http://forum.gsmhosting.com/vbb/10422257-post4.html Next download correct boot repair file (V1 or V2) from this thread: http://forum.gsmhosting.com/vbb/f609...735-a-1830880/ Then repair boot of your phone... | |
02-28-2015, 05:17 | #7 (permalink) |
Member: 19032 Status: Offline Thanks Meter: 158 | I update ATFJ.exe to v1.0.13, received access to support, download NOKIA_XL_V2_RM-1030_FULL_BOOT_1.2.3.21.afp and phone alive: Code: Default language ID 0x0419 JTAG Interface Connected, S/N 0x83F4A58D Resetting and Exploring JTAG chain...No Devices found in Chain! Default language ID 0x0419, LR 12 JTAG Interface Connected, S/N 0x83F4A58D Resetting and Exploring JTAG chain...No Devices found in Chain! Default language ID 0x0419, LR 12 JTAG Interface Connected, S/N 0x83F4A58D Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 28.09.2014 13:33:00 ========================================================== Phone Type : Nokia XL V2 [RM-1030] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: v2 1.2.3.21 ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x1077C0E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D4201FE7FDAB3611E Flash Description: Samsung J5XWMB, 3.64 GiB, SN FE7FDAB3, Jun 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91929 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 1m 30s. Code Download Speed 228 KiB/sec. Boot Restore Done! |
The Following 2 Users Say Thank You to Abzal For This Useful Post: |
