not problem for me, although I can not update software to version 8.95.
14:19:00 : Make sure that you plugged the cable to the
14:19:00 : RJ-45 Port Marked << EXTENSION >>
14:19:00 :
14:19:00 : =======================================
|| FLASHBUS EXTENSION ||
|| | | (O) (O) (O) | CABLE | ||
PLUG IN
CABLE HERE
14:19:39 : VBATT Powering Down <<<<
14:19:41 : VBATT Powering Up >>>>
14:19:41 : SET VCCIO Level Done
14:19:41 : SET BSI Load Done
14:19:41 :
14:19:41 : Booting Phone...
14:19:41 : CPU ID Response: A200341100
14:19:41 : CPU Type: XG110 2.1B
14:19:41 : Phone Booted at after First attempt...
14:19:41 :
14:19:41 : ************************************************** ****
14:19:41 : START INFINEON BUS CHECK
14:19:41 :
14:19:41 :
14:19:41 : Sending PBL 37888 bytes...
14:19:43 : PBL Successfully Sent...
14:19:43 : Sending SBL 65024 bytes...
14:19:44 : SBL Successfully Sent...
14:19:44 :
14:19:44 : Flash Chip Manufacturer: Samsung Electronics Corp.
14:19:44 : Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
14:19:44 : Extended Information: Multiple Bank / Burst / 1.8v
14:19:44 :
14:19:44 : ************************************************** ****
14:19:44 : INFINEON BUS CHECK DONE
14:19:44 :
14:19:51 :
14:19:51 : MCU: V 03.25 16-09-11 RH-130 (c) Nokia
14:19:51 : IMEI: 351656xxxxxxxxx
14:19:51 : Product Serial Number: 78C9315AH
14:19:51 : Product Code : 059H6Q6
14:19:51 : Module Code : 0204875
14:19:51 : Basic Production Code: 059F6X3
14:19:52 : PPM SW Version : V 03.25 16-09-11 RH-130 (c) Nokia ME
14:19:52 : ADSP Version : p+V 03.25\n16-09-11\nRH-130\n(c) NMP\nme_nlt
14:19:52 : MCU SW Version : V 03.25 16-09-11 RH-130 (c) Nokia
14:19:52 : HW Version : 1000
14:19:52 : UEM Version : 1328
14:19:52 : UPP Version : 8850
14:19:53 : LCD Version : TPO:BARACOAv92 HX5081
14:19:54 : ********** SIMLOCK INFO **********
14:19:54 : CONFIG_DATA : 0010100000000000
14:19:54 : PROFILE_BITS : 0000000000040002
14:19:54 : ASIC : 11
14:19:54 : PROVIDER : Default Test Operator
14:19:54 :
14:19:54 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
14:19:54 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
14:19:54 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
14:19:54 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
14:19:54 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
14:19:54 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
14:19:54 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
14:19:54 : ST_LCD_TEST : PASSED
14:19:55 :
14:20:21 : VBATT Powering Down <<<<
14:20:24 : VBATT Powering Up >>>>
14:20:24 : SET VCCIO Level Done
14:20:24 : SET BSI Load Done
14:20:24 :
14:20:24 : Booting Phone...
14:20:24 : CPU ID Response: A200341100
14:20:24 : CPU Type: XG110 2.1B
14:20:24 : Phone Booted at after First attempt...
14:20:24 :
14:20:24 : ************************************************** ****
14:20:24 : TIME STARTS HERE
14:20:24 :
14:20:24 :
14:20:24 : Sending PBL 19456 bytes...
14:20:26 : PBL Successfully Sent...
14:20:26 :
14:20:26 : Sending SBL 65024 bytes...
14:20:27 : SBL Successfully Sent...
14:20:27 :
14:20:27 : Flash Chip Manufacturer: Samsung Electronics Corp.
14:20:27 : Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
14:20:27 : Extended Information: Multiple Bank / Burst / 1.8v
14:20:27 :
14:20:27 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\3.60\rh130_003.600
14:20:27 :
14:20:27 : FIRMWARE Image Found...
14:20:27 : Number of Sections: 03
14:20:27 : FIRMWARE Certificate Block Sent Successfully...
14:20:27 : Processing Section 01 of 03
14:20:27 : FIRMWARE Erase Block: 0x00800000~0x00A0FFFE
14:20:27 : Start Erasing...
14:20:27 : Erasing Please Wait...
14:20:45 : Block Erase Done...
14:20:45 : Preparing Data Blocks...
14:20:45 : Data Size: 2162688 bytes
14:20:45 : Data Checksum: A3CA
14:20:45 : Uploading Data Blocks to phone...
14:21:11 : FIRMWARE Data Blocks uploaded to phone...
14:21:11 : Processing Section 02 of 03
14:21:11 : FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
14:21:11 : Start Erasing...
14:21:11 : Erasing Please Wait...
14:21:31 : Block Erase Done...
14:21:31 : Preparing Data Blocks...
14:21:31 : Data Size: 2334848 bytes
14:21:31 : Data Checksum: BEE7
14:21:31 : Uploading Data Blocks to phone...
14:21:59 : FIRMWARE Data Blocks uploaded to phone...
14:21:59 : Processing Section 03 of 03
14:21:59 : FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE
14:21:59 : Start Erasing...
14:21:59 : Erasing Please Wait...
14:22:00 : Block Erase Done...
14:22:00 : Preparing Data Blocks...
14:22:00 : Data Size: 64 bytes
14:22:00 : Data Checksum: 0000
14:22:00 : Uploading Data Blocks to phone...
14:22:00 : FIRMWARE Data Blocks uploaded to phone...
14:22:00 : Start Data Verification... (Please wait)
14:22:04 : Data Verification Successful...
14:22:04 :
14:22:04 :
14:22:04 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\3.60\rh130_003.60md
14:22:04 :
14:22:04 : PPM Image Found...
14:22:04 : Number of Sections: 01
14:22:04 : PPM Certificate Block Sent Successfully...
14:22:04 : Processing Section 01 of 01
14:22:04 : PPM Erase Block: 0x00210000~0x0044C63E
14:22:04 : Start Erasing...
14:22:04 : Erasing Please Wait...
14:22:24 : Block Erase Done...
14:22:24 : Preparing Data Blocks...
14:22:24 : Data Size: 2344512 bytes
14:22:24 : Data Checksum: F849
14:22:24 : Uploading Data Blocks to phone...
14:22:52 : PPM Data Blocks uploaded to phone...
14:22:52 : Start Data Verification... (Please wait)
14:22:52 : Data Verification Successful...
14:22:52 :
14:22:52 :
14:22:52 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\3.60\rh1300_nai03.60md
14:22:52 :
14:22:52 : CONTENT Image Found...
14:22:52 : Number of Sections: 01
14:22:52 : CONTENT Certificate Block Sent Successfully...
14:22:52 : Processing Section 01 of 01
14:22:52 : CONTENT Erase Block: 0x00EB0000~0x00F0693E
14:22:52 : Start Erasing...
14:22:52 : Erasing Please Wait...
14:22:55 : Block Erase Done...
14:22:55 : Preparing Data Blocks...
14:22:55 : Data Size: 354624 bytes
14:22:55 : Data Checksum: B72F
14:22:55 : Uploading Data Blocks to phone...
14:23:00 : CONTENT Data Blocks uploaded to phone...
14:23:00 : Start Data Verification... (Please wait)
14:23:00 : Data Verification Successful...
14:23:00 :
14:23:00 :
14:23:00 : Exit Flash Mode Done...
14:23:00 : Time Elapse : 00:02:35
14:23:03 :
14:23:03 : ************************************************** ****
14:23:03 : You must Factory Reset the phone to enable the
14:23:03 : ringtones and other customized settings to work
14:23:03 :
14:23:03 :
14:23:03 : Waiting For Phone to go Online...
14:23:03 :
14:23:03 : 5,
14:23:03 : 4,
14:23:03 : 3,
14:23:03 : 2,
14:23:04 : 1...
14:23:04 :
14:23:04 : MCU: V 03.60 17-11-11 RH-130 (c) Nokia
14:23:04 : IMEI: 3516560xxxxxxxxxxxxx
14:23:04 : Product Serial Number: 78C9315AH
14:23:04 : Product Code : 059H6Q6
14:23:04 : Module Code : 0204875
14:23:04 : Basic Production Code: 059F6X3
14:23:05 : PPM SW Version : V 03.60 17-11-11 RH-130 (c) Nokia MD
14:23:05 : ADSP Version : p V 03.60\n17-11-11\nRH-130\n(c) NMP\nmd
14:23:05 : MCU SW Version : V 03.60 17-11-11 RH-130 (c) Nokia
14:23:05 : HW Version : 1000
14:23:05 : UEM Version : 1328
14:23:05 : UPP Version : 8850
14:23:05 : LCD Version : TPO:BARACOAv92 HX5081
14:23:06 : ********** SIMLOCK INFO **********
14:23:07 : CONFIG_DATA : 0010100000000000
14:23:07 : PROFILE_BITS : 0000000000040002
14:23:07 : ASIC : 11
14:23:07 : PROVIDER : Default Test Operator
14:23:07 :
14:23:07 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
14:23:07 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
14:23:07 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
14:23:07 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
14:23:07 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
14:23:07 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
14:23:07 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
14:23:07 : ST_LCD_TEST : PASSED
14:23:07 :
14:23:08 :
14:23:08 : FACTORY SET TO : Full Factory Set
14:23:09 : OK
14:23:09 : FACTORY SET TO : User Data
14:23:09 : OK
14:23:09 : FACTORY SET TO : Leave Factory
14:23:09 : OK
14:23:09 : FACTORY SET TO : Service Center
14:23:09 : OK
14:23:09 : FACTORY SET TO : Software Upgrade
14:23:09 : OK
14:23:09 : FACTORY SET TO : Production Tune
14:23:09 : OK
