07-06-2012, 09:02 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: lahore
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | PLZ help 5230 security test failed.. ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 10.3.12 Software Version : v8.95 AdvanceBox SN : A8DC9*********** Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Please Update Important Files Goto "Product Support" tab then Click "Update Files" tab then Click "UPDATE IMPORTANT FILES" button ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= ================================================ Basic Phone Information ================================================ MCU Version: V ICPR72_10w42.1 23-11-10 RM-593 (c) Nokia IMEI Plain : 358299030145805 IMEI Spare : A358299030145800 IMEI SV : 33582990301458029F Phone Model: Nokia 5230-1c Category : Classic Phone Phone Type : RM-593 ================================================ Extended Phone Information ================================================ Product Serial Number: CZB681854 Product Code : 0577187 Basic Production Code: 0552692 Long Production SN : 0 MCU SW Version : V ICPR72_10w42.1 23-11-10 RM-593 (c) Nokia HW Version : 1101 RFIC Version : 17141716 DSP Version : ICPR72_10w33 AHNE Version : 11 APE SW Core Version : V 40.8.003 Variant Version : V 40.8.003??? APE Test Version : eno_version RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Bluetooth ID : D8:75:33:32:B7:31 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA IV, WCDMA V ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 302320004****** NETWORK NAME : Dave Wireless;Canada [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open Block [2] 1:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL DCC ID : NOT USED ================================================== ==== Selected VPL File: RM593_0592823_12.2.082_001.vpl ================================================== ==== Variant Details : RM-593 5230-1C T-MOBILE WHITE/WHITE Software Version : 12.2.082 Product Type : RM-593 Product Code : 0592823 Variant Version : 001 |
07-06-2012, 09:31 | #3 (permalink) |
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | no sir not solved here is logs ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 3023200044773343 NETWORK NAME : Dave Wireless;Canada [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open Block [2] 1:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST DCC ID : NOT USED |
07-06-2012, 09:38 | #4 (permalink) |
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | sir facing this problem.... Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358299030145805 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" |
07-06-2012, 11:44 | #6 (permalink) |
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | yes brother i did it ,post no 4, i post it in wrong section this is infinity best logs...post no 3 is the logs after authorized and sx4 generic pm...by advance box.... |
07-06-2012, 18:29 | #7 (permalink) |
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | Thanks advance team u r sleeping ,,my problem is solved by infinity best dongle.. here is log.. Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5230-1c Software ver : V ICPR72_10w42.1 23-11-10 RM-593 (c) Nokia IMEI : 3582990******* Ape Ver : V 40.8.003 APE Var : V 40.8.003??? APE ADSP: 256 DSP Ver : ICPR72_10w33 APE Test: eno_version PPM : CNT : v 001_002 03-02-11 vanilla RM593 Product SN : CHJ506413 Product code : 0592823 Base Prd.code: 0585852 Long Prod.SN : 0 Hardware info======= HWID : 0530 Retu : 16 Tahvo : 22 Batery: 3968 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708. APE HW: 256 Lock info =========== IMEI : 3582990****** IMEI spNet : 3A 85 92 09 03 41 85 00 IMEI svNet : 33 85 92 09 03 41 85 20 F9 Conf key : 8000000000000000 Provider key : 3023200044773343 Provider : Unknown Provider Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Open BLK : 2 Lock1:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
07-06-2012, 19:50 | #8 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: DUBAI Age: 33
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | Quote:
f Atf is sleeping so what is this FIRST-IN-THE-WORLD ..... bro | |
07-07-2012, 04:41 | #9 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Hamidshah07 Solution was already posted in POST #2,, it was very simple and very easy... Anyone here who have same problem as you and follow post #2 will fix their phone very easily. If you just say "not work" but you don't post logs about error messages, then we cannot help you further because we don't know for sure what exactly you are doing or what your intentions are. |
07-07-2012, 08:03 | #11 (permalink) | |
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | Quote:
07-07-2012, 08:27 | #12 (permalink) | |
Hamidshah07 time (14:02) post replayed Advance-Box time (14:23) i think there is not the weak r hours time..... bro | |
07-07-2012, 08:32 | #13 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Solution already posted in POST #2, Posted 21 minutes after thread was started. If cannot understand the solution in POST #2, then that is a different problem. Solution is also displayed already in ATF Software Logs SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL DCC ID : NOT USED If cannot understand what that means,, then that is another problem. |
07-07-2012, 08:44 | #14 (permalink) | |
07-07-2012, 10:02 | #15 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Hamidshah07 You want to be cooperative? How about posting error logs you get when you perform post #2... If we can see error logs, then we can help. You see you even post other software error logs in POST #4 (In wrong Section). Why cannot you post error logs for ATF??? I do not have Crystal Ball, I cannot see what is on your PC. If you want help, then help me to help you to help yourself. |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
