09-16-2014, 06:57 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Rm-980 boot repair done but still no power.. need idea! Unit: Nokia X (RM-980 ) Status : Deadboot ( no power ) Tried with my ATF Nitro.. Jtag Logs: Code: Default language ID 0x0409 JTAG Interface Connected, S/N ============ Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/16/2014 12:23:00 PM ========================================================== Phone Type : Nokia X [RM-980] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 1.1.2.2 ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x000000E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501005335584B4D42013EFAC0FF41AE Flash Description: Samsung S5XKMB, 3.64 GiB, SN 3EFAC0FF, Apr 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91499 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...Flash Write Error at 0x003C7A00, Bad Answer from Loader 0x0, 0x1504 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501005335584B4D42013EFAC0FF41AE Flash Description: Samsung S5XKMB, 3.64 GiB, SN 3EFAC0FF, Apr 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...Memory Write Error, Shift IR Error(s) Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x000000E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501005335584B4D42013EFAC0FF41AE Flash Description: Samsung S5XKMB, 3.64 GiB, SN 3EFAC0FF, Apr 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...Memory Write Error, Shift IR Error(s) Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x000000E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501005335584B4D42013EFAC0FF41AE Flash Description: Samsung S5XKMB, 3.64 GiB, SN 3EFAC0FF, Apr 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91454 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 1m 27s. Code Download Speed 235 KiB/sec. Boot Restore Done! ============================================================= Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ============================================================= After assembling the unit.. phone still dead but this time detected as qualcom hs-usb-qd loader.. need help.. thanks!! |
09-16-2014, 08:12 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @parengBok I think your phone is a V2 phone. Check Product code here: http://forum.gsmhosting.com/vbb/10422257-post4.html If your product code is in that list, then it is V2. If that is a V2 phone, then you need to use V2 repair file. NOKIA_X_V2_RM-980_FULL_BOOT_1.1.3.20.afp B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-16-2014, 10:35 | #3 (permalink) |
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Handset PRODUCT CODE 059w138 and it is V2 indeed.. thanks ADVANCE Team.. Boot repair done: Logs: Code: Default language ID 0x0409 JTAG Interface Connected, S/N ========== Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/16/2014 12:23:00 PM ========================================================== Phone Type : Nokia X [RM-980] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 1.1.2.2 ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/8/2014 12:10:00 AM ========================================================== Phone Type : Nokia X V2 [RM-980] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: V2 1.1.3.20 ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x1077C0E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 38, Shift IR Error(s) Restore Boot... Waiting for Device Connection 20 second(s)...Timeout During Operation! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 38, Shift IR Error(s) Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 38, Shift IR Error(s) Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 38, Shift IR Error(s) Restore Boot... Waiting for Device Connection 20 second(s)...Timeout During Operation! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x000000E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501005335584B4D42013EFAC0FF41AE Flash Description: Samsung S5XKMB, 3.64 GiB, SN 3EFAC0FF, Apr 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91498 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 2m 33s. Code Download Speed 353 KiB/sec. Boot Restore Done! ============================================================= Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ============================================================= need link for firmware with Product code: 059w138 |
09-22-2014, 09:38 | #8 (permalink) |
Freak Poster Join Date: May 2013 Location: Nigeria
Member: 1931004 Status: Offline Sonork: 100.1662382 Thanks Meter: 85 | Direct Download RM980 V2 1.2.4.21 system.img @nokia server |
The Following User Says Thank You to binadam23 For This Useful Post: |
