03-10-2014, 05:24 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Samsung Exynos/Qualcomm CPU Test Point Locations for UNBRICK via SD CARD 1. You need to Disassemble Phone and Expose the TP Location 2. Most of these phones have LOCKED JTAG Access, so you cannot "JTAG" these phones 3. This is the OFFICIAL METHOD used by Samsung Service Centers around the WORLD!!! Quick Links: SM-G900H (Galaxy S5) SM-N900 (Galaxy Note 3) I9300 (Galaxy S III) I9500/I9502 (Galaxy S4) N7100 (Note II) SM-C101 (Galaxy S4 Zoom) SM-G7102 (Galaxy Grand 2) SM-N750 Galaxy Note 3 Neo 3G / Note3 Lite SM-N7505/N7505L Galaxy Note 3 Neo Last edited by Advance-Box; 12-06-2014 at 00:34. Reason: added N7100 |
The Following 22 Users Say Thank You to Advance-Box For This Useful Post: |
03-10-2014, 05:38 | #2 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Phone: Samsung SM-N900 (Note 3) CPU: Samsung Exynos 5 Octa 5420 Download SDC Images here: SM-N900 for Android 4.3 SM-N900 for Android 4.4.2 Always Put your Downloaded SDC Files into: C:\AdvanceBox Turbo Flasher\sd_card\SDC_IMAGE\ Here is TP Location: PCB Type 1 PCB Type 2 Short this Resistor using a Tweezer 1. Create SD Card using SDC Tool from ATF. 2. Disassemble phone to expose TP Area. 3. Insert SD Card. 4. Connect Power Supply or Battery. 5. Use TWEEZER TO SHORT that RESISTOR in TP PIX - (BE CAREFUL!! DO NOT DAMAGE RESISTOR!!) 6. Use VOLUME DOWN + HOME + POWER Button to make phone enter SD CARD MODE (You can also use JIG). *** Once phone enter SD CARD MODE, DO NOT SHORT THE RESISTOR ANYMORE!!! *** You will see something like this: SDCARD MODE UP KEY : NORMAL BOOTING DOWN KEY : DOWNLOAD MODE <------------ Select this 6. Flash with ODIN PIT + BL + AP + CP and CSC B.R. Last edited by Advance-Box; 05-15-2014 at 17:34. |
The Following 18 Users Say Thank You to Advance-Box For This Useful Post: |
03-10-2014, 10:57 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Phone: Samsung I9300 Galaxy S III CPU: Samsung Exynos 4412 Quad Download SDC Image here: GT-I9300UBUGMK6_4.3_16GB.sdc Always Put your Downloaded SDC Files into: C:\AdvanceBox Turbo Flasher\sd_card\SDC_IMAGE\ Here is TP Location - Zoomed In: 1. Create SD Card using SDC Tool from ATF. 2. Disassemble phone to expose TP Area. 3. Insert SD Card. 4. Connect Power Supply or Battery. 5. Use TWEEZER TO SHORT that RESISTOR in TP PIX - (BE CAREFUL!! DO NOT DAMAGE RESISTOR!!) 6. Use VOLUME DOWN + HOME + POWER Button to make phone enter SD CARD MODE (You can also use JIG). *** Once phone enter SD CARD MODE, DO NOT SHORT THE RESISTOR ANYMORE!!! *** You will see something like this: SDCARD MODE UP KEY : NORMAL BOOTING DOWN KEY : DOWNLOAD MODE <-------------- Select this 6. Flash with ODIN PIT + BL + AP + CP and CSC BR |
The Following 18 Users Say Thank You to ..::Angel::.. For This Useful Post: |
03-10-2014, 18:07 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Phone: Samsung GT-I9500/GT-I9502 (Galaxy S4) CPU: Samsung Exynos 5 Octa 5410 Download SDC Images here: GT-I9500 for Android 4.2.2 GT-I9500 for Android 4.3 GT-I9502 for Android 4.2.2 GT-I9502 for Android 4.3 Always Put your Downloaded SDC Files into: C:\AdvanceBox Turbo Flasher\sd_card\SDC_IMAGE\ Here is TP Location: Zoomed In... 1. Create SD Card using SDC Tool from ATF. 2. Disassemble phone to expose TP Area. 3. Insert SD Card. 4. Connect Power Supply or Battery. 5. Use TWEEZER TO SHORT that RESISTOR in TP PIX - (BE CAREFUL!! DO NOT DAMAGE RESISTOR!!) 6. Use VOLUME DOWN + HOME + POWER Button to make phone enter SD CARD MODE (You can also use JIG). *** Once phone enter SD CARD MODE, DO NOT SHORT THE RESISTOR ANYMORE!!! *** You will see something like this: SDCARD MODE UP KEY : NORMAL BOOTING DOWN KEY : DOWNLOAD MODE <------------ Select this 6. Flash with ODIN PIT + BL + AP + CP and CSC B.R. |
The Following 8 Users Say Thank You to Advance-Box For This Useful Post: |
03-12-2014, 12:36 | #5 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Phone: Samsung Galaxy Note II N7100 CPU: Samsung Exynos 4412 Quad Download SDC Image here: GT-N7100XXUENA1_4.3_16GB.sdc Always Put your Downloaded SDC Files into: C:\AdvanceBox Turbo Flasher\sd_card\SDC_IMAGE\ Here is TP Location - Zoomed In: 1. Create SD Card using SDC Tool from ATF. 2. Disassemble phone to expose TP Area. 3. Insert SD Card. 4. Connect Power Supply or Battery. 5. Use TWEEZER TO SHORT that RESISTOR in TP PIX - (BE CAREFUL!! DO NOT DAMAGE RESISTOR!!) 6. Use VOLUME DOWN + HOME + POWER Button to make phone enter SD CARD MODE (You can also use JIG). *** Once phone enter SD CARD MODE, DO NOT SHORT THE RESISTOR ANYMORE!!! *** You will see something like this: SDCARD MODE UP KEY : NORMAL BOOTING DOWN KEY : DOWNLOAD MODE <-------------- Select this 6. Flash with ODIN PIT + BL + AP + CP and CSC BR Last edited by Advance-Box; 08-11-2014 at 06:55. |
The Following 11 Users Say Thank You to ..::Angel::.. For This Useful Post: |
04-22-2014, 17:47 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Phone: Samsung SM-G900H (Galaxy S5) CPU: Samsung Exynos 5 Octa 5420 READ FIRST HOW TO DISASSEMBLE WATER-PROOFING ON GALAXY S5 PHONES!!! CLICK HERE FOR GALAXY S5 DISASSEMBLY!!! Download SDC Image here: SM-G900H for Android 4.4.2 Always Put your Downloaded SDC Files into: C:\AdvanceBox Turbo Flasher\sd_card\SDC_IMAGE\ Here is TP Location: Zoomed In... 1. Create SD Card using SDC Tool from ATF. 2. Disassemble phone to expose TP Area. 3. Insert SD Card. 4. Connect Power Supply or Battery. 5. Use TWEEZER TO SHORT that RESISTOR in TP PIX - (BE CAREFUL!! DO NOT DAMAGE RESISTOR!!) 6. Use VOLUME DOWN + HOME + POWER Button to make phone enter SD CARD MODE (You can also use JIG). *** Once phone enter SD CARD MODE, DO NOT SHORT THE RESISTOR ANYMORE!!! *** You will see something like this: SDCARD MODE UP KEY : NORMAL BOOTING DOWN KEY : DOWNLOAD MODE <------------ Select this 6. Flash with ODIN PIT + BL + AP + CP and CSC B.R. Last edited by Advance-Box; 04-22-2014 at 17:53. |
The Following 12 Users Say Thank You to Advance-Box For This Useful Post: |
05-22-2014, 03:01 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Phone: Samsung SM-C101 (Galaxy S4 Zoom) CPU: Samsung Exynos 4212 Dual Core Download SDC Image here: SM-C101_4.2.2.sdc Always Put your Downloaded SDC Files into: C:\AdvanceBox Turbo Flasher\sd_card\SDC_IMAGE\ Here is TP Location - Zoomed In: 1. Create SD Card using SDC Tool from ATF. 2. Disassemble phone to expose TP Area. 3. Insert SD Card. 4. Connect Power Supply or Battery. 5. Use TWEEZER TO SHORT that RESISTOR in TP PIX - (BE CAREFUL!! DO NOT DAMAGE RESISTOR!!) 6. Use VOLUME DOWN + HOME + POWER Button to make phone enter SD CARD MODE (You can also use JIG). *** Once phone enter SD CARD MODE, DO NOT SHORT THE RESISTOR ANYMORE!!! *** You will see something like this: SDCARD MODE UP KEY : NORMAL BOOTING DOWN KEY : DOWNLOAD MODE <-------------- Select this 6. Flash with ODIN PIT + BL + AP + CP and CSC BR Last edited by Advance-Box; 05-22-2014 at 03:26. |
The Following 5 Users Say Thank You to Advance-Box For This Useful Post: |
09-29-2014, 10:42 | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Phone: Samsung SM-G7102 (Galaxy Grand 2) CPU: Qualcomm MSM8226 Download SDC Image here: SM-G7102_442_8GB_G7102XXUBNH6.sdc Always Put your Downloaded SDC Files into: C:\AdvanceBox Turbo Flasher\sd_card\SDC_IMAGE\ *** You ONLY NEED to Perform TESTPOINT METHOD IF Phone Cannot Enter Download Mode when SD Card is inserted. 90% of the Time, you DO NOT NEED TESTPOINT METHOD AT ALL!!! *** For More Information, Read this thread first: http://forum.gsmhosting.com/vbb/10566163-post52.html Here is TP Location - Zoomed In: 1. Create SD Card using SDC Tool from ATF (Use 8GB Branded micro SD Card). 2. Disassemble phone to expose TP Area. 3. Insert SD Card. 4. Connect Power Supply or Battery. 5. Use TWEEZER TO SHORT that RESISTOR in TP PIX - (BE CAREFUL!! DO NOT DAMAGE RESISTOR!!) 6. Use VOLUME DOWN + HOME + POWER Button to make phone enter SD CARD MODE (You can also use JIG). *** Once phone enter SD CARD MODE, DO NOT SHORT THE RESISTOR ANYMORE!!! *** You will see something like this: 7. Remove micro SD Card from Phone!!! Make sure "PIT" File is Included and "Re-Partition" is selected in ODIN!!! 8. Flash with ODIN PIT + BL + AP + CP and CSC For More Information, Read this thread: http://forum.gsmhosting.com/vbb/10566163-post52.html BR |
The Following 11 Users Say Thank You to Advance-Box For This Useful Post: |
12-05-2014, 22:58 | #9 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Phone: Samsung SM-N750 (Galaxy Note 3 Neo 3G / Note3 Lite) CPU: Samsung Exynos 5 Hexa 5260 Download SDC Image here: SM-N750 SDC Files Always Put your Downloaded SDC Files into: C:\AdvanceBox Turbo Flasher\sd_card\SDC_IMAGE\ Here is TP Location - Zoomed In: 1. Create SD Card using SDC Tool from ATF (Use 8GB Branded micro SD Card). 2. Disassemble phone to expose TP Area. 3. Insert SD Card. 4. Connect Power Supply or Battery. 5. Use TWEEZER TO SHORT that RESISTOR in TP PIX - (BE CAREFUL!! DO NOT DAMAGE RESISTOR!!) 6. Use VOLUME DOWN + HOME + POWER Button to make phone enter SD CARD MODE (You can also use JIG). *** Once phone enter SD CARD MODE, DO NOT SHORT THE RESISTOR ANYMORE!!! *** You will see something like this: 7. Remove micro SD Card from Phone!!! Make sure "PIT" File is Included and "Re-Partition" is selected in ODIN!!! 8. Flash with ODIN PIT + BL + AP + CP and CSC BR |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
12-06-2014, 00:28 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Phone: Samsung SM-N7505/SM-N7505L (Galaxy Note 3 Neo 3G / Note3 Lite) CPU: Samsung Exynos 5 Hexa 5260 Download SDC Image here: SM-N7505 SDC Files SM-N7505L SDC Files Always Put your Downloaded SDC Files into: C:\AdvanceBox Turbo Flasher\sd_card\SDC_IMAGE\ Here is TP Location - Zoomed In: 1. Create SD Card using SDC Tool from ATF (Use 8GB Branded micro SD Card). 2. Disassemble phone to expose TP Area. 3. Insert SD Card. 4. Connect Power Supply or Battery. 5. Use TWEEZER TO SHORT that RESISTOR in TP PIX - (BE CAREFUL!! DO NOT DAMAGE RESISTOR!!) 6. Use VOLUME DOWN + HOME + POWER Button to make phone enter SD CARD MODE (You can also use JIG). *** Once phone enter SD CARD MODE, DO NOT SHORT THE RESISTOR ANYMORE!!! *** You will see something like this: 7. Remove micro SD Card from Phone!!! Make sure "PIT" File is Included and "Re-Partition" is selected in ODIN!!! 8. Flash with ODIN PIT + BL + AP + CP and CSC BR |
The Following User Says Thank You to Advance-Box For This Useful Post: |
