Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-20-2016, 18:12   #346 (permalink)
Member: 942321
samsung J700H ,i was repair boot succesfully but phone not power on.
i can not flash to repaire phone.
i have try 5 firmwares and android 6.0.1 ,same probleme .
who have solution for me thanks
phone is coming to UAE (LYS) language
J700H_XXU1AOGA_OXY1AOGA
J700HXXU1AOG3_OXY1AOFG_v5.1.1
J700HXXU1AOG9_J700HOJV1AOGA_J700HXXU1AOG6_HOME.tar
J700HXXU2BPF9_J700HOJV2BPF4_XSG_2
LYS-J700HXXU1AOK5-20160111103930
Old 07-23-2016, 14:43   #347 (permalink)
Member: 738146
Thanks Meter: 18
please any one can share image of skyhynix emmc pinout for j700h thanks
Old 07-23-2016, 14:50   #348 (permalink)
Member: 1406640
Sonork: 39900891
Thanks Meter: 107
all j7 emmc pinout are same only cpu,diffrent
The Following User Says Thank You to kimt team std5 For This Useful Post:
Old 07-24-2016, 09:23   #349 (permalink)
ajmobilesshop's Avatar
Member: 2602390
Thanks Meter: 106
samsung g530h dadboot riper????????????????
Old 07-24-2016, 09:27   #350 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Open you eyes and Not post anywhere:
http://forum.gsmhosting.com/vbb/f609...100-a-2109448/
The Following User Says Thank You to allumts For This Useful Post:
Old 07-25-2016, 12:50   #351 (permalink)
Member: 1406640
Sonork: 39900891
Thanks Meter: 107
your data 0 resister is connected in wrong way.
Old 07-26-2016, 08:08   #352 (permalink)
Member: 1532868
Sonork: 100.1640331
Thanks Meter: 36
J700f Dead Boot Raper
Need Help About This Problem
http://www.4shared.com/photo/dXm253Vvce/Screenshot.html
Any Body Tell Me How To Solve This Problem
Old 07-31-2016, 20:29   #353 (permalink)
Member: 1406640
Sonork: 39900891
Thanks Meter: 107
What is your phone CPU
Old 07-31-2016, 20:43   #354 (permalink)
allumts's Avatar
Member: 1564612
Hello,
for this Basic knowledge Google is very good friend for you ...
Old 07-31-2016, 20:47   #355 (permalink)
allumts's Avatar
Member: 1564612
Screenshot - Download - 4shared - Amir Ali
Start posting Clear Photo, what action have done, what Adapter are using, (if using), and what type of Atf you have BIG or Light/Nitro.
Later if read first post, i'm sure that you not get Tired
allumts
Old 08-03-2016, 03:11   #356 (permalink)
musfiqur rahman's Avatar
Member: 1482831
Thanks Meter: 29
[QUOTE=Diamond Gsm;11643006]full dumps from lastet version and alive phone ( J700HXXU1APA3_J700HOJV1AOK6_KSA )
write with ATF
J700h-DS - Download - 4sha
red - Gsm Diamond
After write phone did not download mode
Old 08-08-2016, 14:11   #357 (permalink)
Member: 942321
Old 08-13-2016, 20:24   #358 (permalink)
gsmnitinmobile's Avatar
Member: 1595511
Sonork: nnn
Thanks Meter: 121
Not not ok plz hellp
Old 08-14-2016, 10:08   #359 (permalink)
Member: 1406640
Sonork: 39900891
Thanks Meter: 107
pakphones please help me to repair my j700h/ds skhynix cpu
tell us witch bootloade file work in skhynix cpu or upload working file
Old 08-15-2016, 18:41   #360 (permalink)
Member: 1189070
Thanks Meter: 167
i have J700F/DD loading on bootloader writing
here is log Scan eMMC
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V, 3.0-3.1V
2.9-3.0V, 2.8-2.9V, 2.7-2.8V
CID : 2C040000000000000000000303C3FBFF (CRC7 Fail 0x9B)
CSD : AC04000000000000000000000343FBFB (CRC7 Fail 0xBF)
eMMC Boot Information
Revision 1.0 (for MMC v4.0)
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 0 KB
HC ERASE GROUP SIZE: 0 KB
USER AREA SIZE : 0 BYTES
BOOT PARTITION SIZE: 0 KB
RPMB PARTITION SIZE: 0 KB
eMMC Device Information
Manufacturer ID: 2C
Device Type : Removable Card
Application ID : 00
Product Name :
Product Rev : 0.0
Product SN : 000303C3
Manufactured : January 2008
Card Specific Data
CSD_STRUCTURE : Version 1.2
SPEC_VERS : Reserved
TAAC : 1 ns
TRAN_SPEED : 0 KHz
READ_BL_LEN : 1 Bytes
WP_GRP_ENABLE : NO
WRITE_BL_LEN : 8192 Bytes
CONTENT_PROT_APP : YES
PERM_WRITE_PROTECT: YES
TMP_WRITE_PROTECT : YES
Extended CSD Saved:
2C040000000000000000000303C3FBFF.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Page generated in 0.21563 seconds with 9 queries
