Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-13-2010, 14:13   #1 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks Meter: 29,604
What is ATF [Advance Turbo Flasher] ?
ATF [Advance Turbo Flasher] Features:
Unique Hardware Features:
480 mbps HIGH-SPEED USB 2.0 Connection ( First In World )
- PC connection is 40 times faster than any other box in the market
100% FPGA based implementation of the flash bus protocols( First In World )
-Significantly faster and more stable than regular MCU based boxes
Adjustable VCCIO Logic Levels (3.30v, 2.80v and 1.80v)
-Compatible with old phone model Logic Level (3.30v)
-Compatible with new phone model Logic Level (2.80v)
-Compatible with future phone model Logic Level (1.80v)
Proper ESD protection on the FLASHBUS port
-Protects phone damage due to Electro Static Discharge
Ultra Fast Flash Clock currently upto 15 Mhz (First In World )
-Firmware updatable to support upto 60 Mhz without the need
of hardware modifications
Internal VPP Flash Voltage Generator (3.0v, 5.0v, 9.0v and 12.0v)
-Makes Flash Erasing on slow phones faster
-Does not require external power adapters to generate 9.0v and 12.0v
-Uses a Fast Switching SEPIC design
Hardware Upgradable using internal Expansion Slots
Micro-SD Card Slot for future developments
Dual RJ-4x Ports (RJ-45 and RJ-48) for External Communication
-The RJ-45 Port is the main "Turbo" Bus
-The RJ-48 Port is the Secondary Bus that can be made
to support parallel or serial protocols such as 2Mbps UART,
JTAG, and Flashing Protocols.
5 Multi Colored LED Indicator Lights
-Rectangular Orange : FBUS_RX
-Rectangular Green : FBUS_TX
-Circular Blue : USB_POWER / ACP-X_POWER
-Circular Green : VBATT
-Circular Orange : VPP
Unique Software Features:
As the Name Itself says its a powerful tool which can flash all Nokia phones including new protocols via Fbus cable in unbelievable speed and stability in compare of any other 3rd party tool which currently present in market
- New Protocols Device X3 ,X6 ,E52 ,E55 ,6700 ,etc and all Rapuyama Fbus Flashing (First In World)
- High Speed Turbo Flashing with Full Speed (First In World)
Tuning & Maintenance
- Life Timer Tuning not only reset but you can write your desire life time(First In World)
- Factory Reset
- Warranty Edits
- Production Data Edits
- Camera Configuration Read/Write
Imei & locks
- Unlock Using Code Calculation so no more damages to phone warranty or certificates ( Supports SL1 SL2 & Some So called SL3 )
- Unlock / Relock Using RPL Method
- Super Dongle Key Repair
PM ( Permanent Memory)
- Read Write Permanent Memory Using SX4 Server
Phone Test
- For Self Test Phone Features
We will update features when we complete more feature on which we are working now.
More cool things still under development.
Buy only from ATF (Advance Turbo Flasher) authorized resellers:
ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
ATF [Advance Turbo Flasher] official web sites:
International - http://www.advance-box.com/
ATF [Advance Turbo Flasher] official support forums:
World Wide: Advance Turbo Flasher - GSM-Forum
Indonesia: ATF (Advance Turbo Flasher))
Philippine: Gsmph
Syria: Arabic Support (Syria) GsmVIP
Chinese support forum : ATF Box
Vietnam: Saigonmobile
!!! Feel The Power Of Turbo Flashing Speed !!!
The Following 82 Users Say Thank You to gsmfun For This Useful Post:
Old 03-13-2010, 14:58   #2 (permalink)
roshantelecom&s's Avatar
Member: 368546
Thanks Meter: 235
nice and must use in ur mobile repairing shop
The Following 2 Users Say Thank You to roshantelecom&s For This Useful Post:
Old 03-14-2010, 11:01   #3 (permalink)
Member: 757799
Thanks Meter: 782
add also all supported units.
The Following 2 Users Say Thank You to trio1 For This Useful Post:
Old 03-16-2010, 15:19   #4 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
Yes, very powerful box for flash etc, more feature will be soon :-)
Stock instant, Can order from us (www.eoem.cc)
BR.,
Denis
The Following 2 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 03-16-2010, 17:12   #5 (permalink)
irfanboss's Avatar
Member: 256247
Thanks Meter: 444
remove your tourbo flasher box it is very very very bad box of year 2010
i throw in toilet
not working no
no dct4
no usb flashing
not for all models
every time showing erer erer erere
i buy this box in indian rupee 6500 rs
i want sale this box 5000rs if any one are intersted plz call me in india 09892399914
The Following 2 Users Say Thank You to irfanboss For This Useful Post:
Old 03-16-2010, 20:28   #6 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
i throw in toilet
not working no
no dct4
no usb flashing
not for all models
before shouting can you tell me where is your problem ?
or you only know shouting language so i can talk with you in you language ?
or you were screwed by our competitor ?
so now tell me what is your problem ?
The Following 4 Users Say Thank You to Javajohn For This Useful Post:
Old 03-17-2010, 02:26   #7 (permalink)
Momo_Gsm's Avatar
Member: 755709
Sonork: 100.1592000 Momo...
Thanks Meter: 6,635
good new box for sure overtaking previous errors of other tools.
The Following 2 Users Say Thank You to Momo_Gsm For This Useful Post:
Old 03-17-2010, 07:55   #8 (permalink)
irfanboss's Avatar
Member: 256247
Thanks Meter: 444
every time i asked my box not working every time erererer
i download new version but my problem is same
i formate my destop but problem is same
now plz tel me what i do
The Following User Says Thank You to irfanboss For This Useful Post:
Old 03-17-2010, 08:06   #9 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
not working means what ? what not working ?
did you post any logs? did you contact any team members for your problem?
did you discusse your problem with any team member?
look just contact me so i can help you
Sonork: 100.50000
yahoo: javajohn222
The Following 5 Users Say Thank You to Javajohn For This Useful Post:
Old 03-17-2010, 08:08   #10 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Do you using sonork or MSN, add me. I can help you.
Thomas
The Following 2 Users Say Thank You to gsmfun For This Useful Post:
Old 03-27-2010, 13:45   #11 (permalink)
Member: 1017775
Sonork: 20442044
Any new device has his merits! The key is to see your team to do the follow-up service!
I have bought the equipment, initial sense is good still! Hope you be perfected as soon as possible
The Following User Says Thank You to 20442044 For This Useful Post:
Old 03-27-2010, 15:43   #12 (permalink)
tcdxb's Avatar
Member: 314698
Thanks Meter: 47
ATF Best BOX Ever Handled
Hi Im from Golden Motor Telecom - Telecare Service Center Dubai U.A.E. I just bought ATF from TST and its really work fast flashing and make dead phone!!! More Power to ATF Team!!
from
tcdxb
The Following User Says Thank You to tcdxb For This Useful Post:
Old 03-27-2010, 16:15   #13 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks for the advice We will do our best to make our software perfect. We just need sometime, step by step to do it.
Thomas
The Following 4 Users Say Thank You to gsmfun For This Useful Post:
Old 03-28-2010, 03:42   #14 (permalink)
Member: 458735
Thanks Meter: 2
中文支持一个………………………………································ ······································
The Following User Says Thank You to 时龙飞 For This Useful Post:
Old 03-28-2010, 03:59   #15 (permalink)
neilthirumuttam's Avatar
Member: 15903
Sonork: 100.1583162
Thanks Meter: 1,046
Thomas
the priorty should be given to flash and unlock DCT4 ., 4+, WD2 & BB5-sl2 phones first.then 4 repairing sd sl SL3 etc
then usb support ,
only after achieve the status of perfect nokia tool go for non nokia tab.
presently all users of ATF bought it for repairing nokia phones , so wishing the team all the best to make it perfect nokia tool
regards,
NEIL
The Following User Says Thank You to neilthirumuttam For This Useful Post:
ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List gsmfun Advance-Box 217 01-31-2018 10:15
ATF v12.70 Update!! 31 MAR 2017!! gsmfun Advance-Box 79 03-31-2017 15:31
ATF [Advance Turbo Flasher] version v2010.0.1.21 discussion thread gsmfun Advance-Box 32 07-24-2010 19:09
ATF [Advance turbo Flasher] Version v2010.0.1.22 update!! 17 Mar 2010 gsmfun Service Products News & Updates 0 03-17-2010 18:26
ATF [Advance turbo Flasher] Version v2010.0.1.21 update!! 12 Mar 2010 gsmfun Service Products News & Updates 0 03-11-2010 18:37
Page generated in 0.29628 seconds with 10 queries
