World's Fastest SL3 LBF "MARKOV" EDITION ---> oclHashcat-lite v0.10 by atom !!! Welcome to oclHashcat-lite v0.10. Download it here: http://hashcat.net/oclhashcat-lite/ Code:
Full Change Log: Code: type: feature Welcome to oclHashcat-lite v0.9. Message from Atom (Hashcat-Lite Developer + Bruteforce Guru) Code:
Official Download Link: http://hashcat.net/oclhashcat-lite/ Official Hashcat Forum: http://hashcat.net/forum/ Official SL3 BF Cracking Guide http://hashcat.net/wiki/cracking_sl3/ oclHashcat now have a special SL3 Kernel with 12.24% Speed Increase on ALL SL3 LBF Tasks!!! Download here: (yes it's 100% free) Download oclHashcat-lite-0.06.7z - hashcat, advanced password recovery Changelogs from v0.05 to v0.06 Code: * changes v0.05 -> v0.06: 8,8xx Million Hash Per Second! HW Specs: 4 x 5870 @ 980 Mhz http://174.120.45.27/tmp/hash_cat_6.png New and Faster SL3 LBF Kernel UPDATE for oclHashcat-lite v0.05 by atom Official Download Link: Download oclHashcat-lite-0.05.7z - hashcat, advanced password recovery Official oclHashcat-lite Homepage: oclHashcat-lite - advanced password recovery Official Discussion Forum and Discussion Thread: hashcat Forum Featuring: 1. Ultra Fast and Stable SL3 Kernel 2. Upto 4% Faster HASH Speeds on 5xxx and 6xxx Cards 3. 100% Free Software !!! 4. Fixed --restore for Resuming BF Tasks 5. Easier Command Line IMPORTANT CHANGES FOR COMMANDLINE INPUT 1. Change -m 101 into -m 1900 2. Change --output-file into --outfile 3. No need to use --pw-min and --pw-max 4. No need to use --hex-charset --hex-salt EXAMPLE: ORIGINAL COMMANDLINE for v0.03: oclHashcat-lite64 3D5D9E11835243015407B7BA327E30CCB70F4DB0:003519730379149500 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=351973037914952.txt NEW COMMANDLINE for v0.05: oclHashcat-lite64 3D5D9E11835243015407B7BA327E30CCB70F4DB0:003519730379149500 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=351973037914952.txt REAL SPEED with 2 x HD 6990 @ 950 Mhz, 7,6xx MILLION HASH per Second !!! http://174.120.45.27/tmp/6990_v04.png REAL SPEED with 2 x HD 5970 @ 950 Mhz, 7,8xx MILLION HASH per Second !!! http://174.120.45.27/tmp/5970_v04.png Fastest SL3 LBF Free and UPDATED!! OlcHashcat-lite v0.03 by atom!! (HD6xxx Supported). Thanks to atom for providing us with 100% Free and 100% fast SL3 LBF Software. Also 100% support for new ATI 6xxx cards (6970, 6990 etc)... BR Thomas BUGFIXES in v0.03 type: bug file: cudaHashcat-lite, oclHashcat-lite desc: fixed a bug in security causing hash was not found randomly cred: RaNdy type: bug file: cudaHashcat-lite, oclHashcat-lite desc: fixed a bug in --restore if command-line contains --pw-skip cred: Ciukut type: bug file: cudaHashcat-lite, oclHashcat-lite desc: fixed a bug in --restore if command-line contains --pw-min cred: hermix information taken from: oclHashcat-lite v0.03 official download area: oclHashcat-lite - advanced password recovery GPU Driver and SDK Requirements:
================================================== For more information about how to setup Windows or Ubuntu with oclHashcat-lite, you can visit atom's official forum or you can also post your inquiries in ATF Section on this thread: Fastest LBF Free Download!! OlcHashcat-lite v0.2!! HD6xxx Supported! You can now build yourself the fastest LBF "******* PC" by using: Motherboard: MSI Big Bang Marshal Video Card: 8 pieces ATI 6970 This will give you 14,170 Million HASH/s on STOCK CLOCKS... Overclock with give you more than 15,xxx HASH/s and the video cards will still be less than 80 degrees celcius with the stock cooling system. ================================================== ================================================== Here is OFFICIAL and UPDATED "HOWTO" for hashcat-lite v0.02 oclHashcat-lite SL3 cracking howto Check out Post # 6 Where atom discusses about MULTIPLE PC Setups to attack a single phone. atom's forum is 100% open for discussion about his work... [B]Happy BF to all! |
for............... speed ................. ATF and.................. what the best for ATI 6XXXX series ? :) |
BR Thomas |
How to use??? :D ........................ |
oclHashcat-lite, advanced password recovery Usage: oclHashcat-lite64 [options] hash [mask] Startup: -V, --version print version -h, --help print help --eula print eula Logging and Files: --quiet enable quiet -o, --output-file=FILE output-file for recovered hash --output-format=NUM 0 = hash:p*** 1 = hash:hex_pass 2 = hash:p***:hex_pass Misc: --hex-salt assume salt is given in hex --hex-charset assume charset is given in hex --runtime=NUM automatically abort session after NUM seconds Resources: --restore restore previous session --gpu-async use non-blocking async calls -d, --gpu-devices=STR CUDA devices to use, seperate with comma -n, --gpu-accel=NUM workload tuning: choose 1, 8, 40, 80 or 160 scales best if you choose the number of SP per SM --gpu-loops=NUM workload fine-tuning if -n is not precise enough --gpu-watchdog=NUM automatically abort session if NUM celsius (ATI only) Built-in charsets: ?l = abcdefghijklmnopqrstuvwxyz ?u = ABCDEFGHIJKLMNOPQRSTUVWXYZ ?d = 0123456789 ?s = !"#$%&'()*+,-./:;<=>?@[\]^_`{|}~ ?h = 8 bit characters from 0xc0 - 0xff ?D = 8 bit characters from german alphabet ?F = 8 bit characters from french alphabet ?R = 8 bit characters from russian alphabet Custom charsets: -1, --custom-charset1=CS user-definable charsets -2, --custom-charset2=CS example: -3, --custom-charset3=CS --custom-charset1=?dabcdef -4, --custom-charset4=CS sets charset ?1 to 0123456789abcdef Attack options: --pw-min=NUM password-length minimum --pw-max=NUM password-length maximum Attack modes: -m, --hash-mode=NUM number of hash-mode 0 = MD5 1 = md5($pass.$salt) 3 = md5(md5($pass)) 5 = vBulletin 100 = SHA1 101 = sha1($pass.$salt) 300 = MySQL4.1/MySQL5 900 = MD4 1000 = NTLM 1100 = Domain Cached Credentials 1400 = SHA256 Example for Windows XP/Vista/7 64-bit and ATI Cards 5xxx or 6xxx: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 32-bit and ATI cards 5xxx 6xxx: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 oclHashcat-lite32 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 64-bit and NVIDIA Cuda Cards: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 cudaHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 32-bit and NVIDIA Cuda Cards: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 cudaHashcat-lite32 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt B.R> |
hmm... start to make totorial how to use it with ATF sir, then ATF would be the Leading in Nokia SL3. Undoubtly !! |
The soft is ready to use, but i don't know how I cant open it i have win 7 64b and latest catalist driver HOW!! HOW!! HOW!! HOW!! |
Step 1: Download Catalyst 11.3 with Integrated OCL Driver here for Windows 7 64 bit... ATI Radeon Download Catalyst 11.3 with Integrated OCL Driver here for Windows 7 32 bit... ATI Radeon Step 2: Download oclHashcatlite software by atom here: oclHashcat-lite - advanced password recovery Step 3: Now let us convert your LOGS for Local Brute Force command line: Example File: 356046033398077.sha Open 356046033398077.sha in Notepad and you will see this: 0FA0023A35BE661697AAE37123CF06D18940C9E0 This is your HASH... And your IMEI is ... 356046033398077 Now take your HASH and first 14 digits of the IMEI and compose command line like this: Example for Windows XP/Vista/7 64-bit and ATI Cards 5xxx or 6xxx: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 32-bit and ATI cards 5xxx 6xxx: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 oclHashcat-lite32 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 64-bit and NVIDIA Cuda Cards: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 cudaHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 32-bit and NVIDIA Cuda Cards: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 cudaHashcat-lite32 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt B.R> |
1 Attachment(s) @thomas or just simply use the GUI version.... http://forum.gsmhosting.com/vbb/atta...1&d=1302493462 br freddy gsmph |
Well this is an independent software and can be useful to crack the hash decrypted (Read Nokia SL3 :)) by ATF or any other similar gsm industrial software tool. BR :) |
