07-11-2012, 11:59 | #1 (permalink) |
Junior Member Join Date: May 2012 Location: Uzb/Tashkent region/Bekabad
Member: 1760081 Status: Offline Thanks Meter: 4 | X2-00 (RM-608) MTP Device USB Connecting Problem - [SOLVED] Now Fone Trying To Connect With USB, Mostly Drivers Found But In End Of Drivers Installing Its Still On Found New Hardware MTP Device, Now Help Me To Connect Plz |
07-11-2012, 12:07 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @speed10000 What version of ATF are you using? The last few versions of ATF already support "BUSCHECK" via USB. This will force phone into Local/Test mode. For MTP Problems, it is windows... But you DO NOT NEED drivers for that anyway... You just need to wait and wait and wait (about 1-3 minutes) until your X2-00 will be ready and available for "SCAN PHONE". So just click SCAN PHONE and wait... if it times out, click SCAN PHONE again... In the END, you will detect it, just as long as your battery have good charge and that nothing else is wrong with the phone. B.R. |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
07-11-2012, 13:58 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
You can cancel this MTP driver installation. And let windows install other drivers for this phone. After you can click on Scan Phone button It will detect your phone. Other way is: Power off phone Tick USB Mode in ATF Software Click on "Bus Check" button .. Insert USB cable to powered off phone When you see MTP driver installation - cancel it.. BR | |
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post: |
07-11-2012, 14:50 | #5 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Yes it is possible,, but you need to follow this correctly: Make sure you set: Start Address: 07540000 End Address: 07FFFFFF After you read the PMM area, you will get an 11 MEGABYTES binary file. You need to use WINRAR or WINZIP to COMPRESS the 11 mb file into a small 100KB or less RAR or ZIP file... Then attach that small file here, and I will open it and post your security code here for you... B.R. | |
07-11-2012, 15:18 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Turn On Phone,, Enter Sec Code: 255225 if it does not accept,,, wait 6 minutes, and enter it again. B.R. X |
The Following 4 Users Say Thank You to Advance-Box For This Useful Post: |
07-13-2012, 10:08 | #9 (permalink) |
Junior Member Join Date: Jul 2012 Location: KAZAKHSTAN-ASTANA
Member: 1784110 Status: Offline Thanks Meter: 2 | Hi everyone, Dear beside you mistake here is here X2-00 (RM-608) RM618 On USB to was necessary give cheque and after cheque beside you was локал and then was necessary wait 1-5 minutes and will press info here is as I |
The Following User Says Thank You to FARI-N1 KZ For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
