01-26-2011, 18:15 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: GULMI Age: 49
Member: 143007 Status: Offline Thanks Meter: 141 | x3-02 white screen pls chk and write ans me now your x3-02 bilinking and white screen chk log,... Number of Image Files: 3 Processing Image File : rm639__05.65.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 328 Entry Point: 0x0267 Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : rm639__05.65.ppm_meac CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 56 Entry Point: 0x0129 Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : rm639__05.65.image_meac_0598435_005 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 217 Entry Point: 0x015A Page Format : -1 MAX PAGE : 0x00020000 AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001051 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 13000217 ID DWORD 1 : A2130049 ID DWORD 2 : 2E413E69 ID DWORD 3 : 87FD42B1 ID DWORD 4 : DFC5F93E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B START FLASHING RawLoaderExtract: Processing rm639__05.65.mcusw Match LOADER : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2n d.fg Loader Uploaded..... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> K5W1G13ACB Extended/Fixed ID : 0000 Revision ID : 0431 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 ROOTHASH : 916F75217F32081248B15C38DFC8E81B Match File.....C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XS R17_alg.fg Done! FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 PAPUB Keys Hash : 23B57C26A0C7A9C34544727AA1D2FC8F3265329C ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-639\ ImadeFilename: rm639__05.65.mcusw Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 000A0000 Size : 02C20000 Partition 2 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 03340000 Size : 04200000 Partition 3 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 07540000 Size : 00600000 Partition 4 ID : 0000000B Attribute : 00000001 RW Start Address : 07B40000 Size : 00180000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A000002C20000000000080000000103340000042000 000000000A0000000107540000006000000000000B00000001 07B4000000180000A0 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0xE9 (233) ERASE Blocks : 0x04 (4) 0 ERASE_AREA_BB5 0x12 Block Length : 0x53 (83) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-000203FF 1 : 00060000-0009FFFF 2 : 000A0000-0041FFFF 3 : 00420000-0069FFFF 4 : 006A0000-006DFFFF 5 : 006E0000-0123FFFF 6 : 02060000-020BFFFF 7 : 02CC0000-0333FFFF 8 : 07540000-07B3FFFF 9 : 01240000-0205FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000 3 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info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uccessfully erased.. Total blocks to write : 328 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : MCUSW1 >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : ISA+DYNSW ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-639\ ImadeFilename: rm639__05.65.ppm_meac StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 020C0000-02CBFFFF ERASE_REQUEST_BB5 : 5001120B000300020C000002CBFFFF05 Successfully erased.. Total blocks to write : 56 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-639\ ImadeFilename: rm639__05.65.image_meac_0598435_005 StartErase_DCT5... BlockLength : 0x3F (63) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 03340000-0753FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5001120B000300033400000753FFFF4F ERASE_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E Successfully erased.. Total blocks to write : 217 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000003 Additional Bad : 00000003 Correctable ECC : 00000000 FlashInfo.RestartMode : 2 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:17 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 100 seconds) If Windows is Installing Drivers... Phone Polling MIGHT Exit Automatically. Elapsed Time: 5 Seconds... Elapsed Time: 10 Seconds... Elapsed Time: 15 Seconds... Elapsed Time: 20 Seconds... Elapsed Time: 25 Seconds... Elapsed Time: 30 Seconds... Elapsed Time: 35 Seconds... Elapsed Time: 40 Seconds... Elapsed Time: 45 Seconds... Elapsed Time: 50 Seconds... Elapsed Time: 55 Seconds... Elapsed Time: 60 Seconds... Elapsed Time: 65 Seconds... Elapsed Time: 70 Seconds... Elapsed Time: 75 Seconds... Elapsed Time: 80 Seconds... Elapsed Time: 85 Seconds... Elapsed Time: 90 Seconds... Elapsed Time: 95 Seconds... Elapsed Time: 100 Seconds... WARNING: Phone is not in the Required Mode... Disconnect the Phone and Power it Up Manually. |
how to unlock a 6150 with v5.02 | stefan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 01-29-2001 11:11 |
6150 VER 5.02 | AMTX99 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-19-2000 03:53 |
Nokia 6150 5.02 Stupid Security Code!!! | Ringnet | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-04-2000 01:27 |
Screening indicator | cxara | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-09-1999 09:13 |
