11-09-2011, 09:00 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 283134 Status: Offline Thanks Meter: 32 | t-mobile exca 100 unlocking problem Logs: Selected model: Excalibur Set Security Policy ...Done. Reading Simlock data ... Running MemDump task ... Connected. Syncing from bkondisk.exe to dev:\ "bkondisk.exe"Copying (New) ... 0/21 k 21/21 k ok CopyProcessMemoryToFile(00000042, b002709c, 00000010, simlock\docid.bin) Connected. Syncing from dev:\simlock.bin to simlock "simlock.bin"Copying (Newer) ... 0/256 k Error copying: "\simlock.bin" to "simlock\simlock.bin" Copy Failed Usage: CeCopy [options] Source_FileSpec Destination Options: /is Include same files /s Include subdirectories Arguments: Source_FileSpec File specification denoting the source of the copy. Destination Where files should be copied to. For the source, wild cards or directory names may be specifed, as may be single files. The destination can be either a directory or a file name, depending on the type of source specified. By default, an argument is assumed to live on a local filesystem. To indicate that either argument denotes a location on a device connected via ActiveSync, prepend 'dev:' to that argument. To articulate that a local filesystem is referenced, prepend 'desk:' to the argument. Exiting. Simlock data dumped OK. Loading simlock.bin 0x20000... Invalid simlock block! Active sync properly installed Pls help TIA |
The Following User Says Thank You to the eraser For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
