02-17-2012, 18:55 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: türkiye Age: 59
Member: 7114 Status: Offline Thanks Meter: 51 | imeirepair elf, [ALL OMAP BUG IN AXEBOX SW] > Connecting to Server... > Connected! > Identifying with Server... > Identified! > Getting Authorisation... > Authorised! imei repair button pressed > READY > BoxSerial: 4B97xxxx > Detected: HTC Elf/Elfin > Device already unlocked, nothing to do > Failed contacting server, this shouldn't happen, terminated. > Operation Time: 42 secs |
02-17-2012, 20:04 | #2 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | You got problem with firewall in windows or in router or your internet provider blocking ports that axebox use. On server side all is ok. |
02-18-2012, 10:51 | #3 (permalink) |
Member: 7114 Status: Offline Thanks Meter: 51 | something is wrong I press imei repair button but server says : Device already unlocked, nothing to do this is wrong answer!!!!! pls check sometimes answer is : Failed contacting server, this shouldn't happen, terminated. this can be normal |
02-18-2012, 11:15 | #4 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Man but what you want do IMEI change or Unlock ?? SOftware just say you that you try unlock phone that is unlocked before then that should write if phone is unlocked. |
02-18-2012, 15:43 | #6 (permalink) |
Member: 7114 Status: Offline Thanks Meter: 51 | > Connecting to Server... > Connected! > Identifying with Server... > Identified! > Getting Authorisation... > Authorised! imei repair button pressed..................... > READY > BoxSerial: 4B97xxxx > Detected: HTC Elf/Elfin > Device already unlocked, nothing to do pls check what it is wrong... |
02-20-2012, 14:58 | #7 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Hi do you use latest installer from 01.2012 ?? http://forum.gsmhosting.com/vbb/f616...012-a-1414379/ |
02-21-2012, 10:37 | #8 (permalink) | |
Member: 7114 Status: Offline Thanks Meter: 51 | Quote:
pls check server ,Ithink omap imei repair has mistake server side thank your support | |
04-02-2012, 18:53 | #9 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 789577 Status: Offline Sonork: 1601878 Thanks Meter: 39 | READY > BoxSerial: > Detected: HTC Elf/Elfin > Device already unlocked, nothing to do > Beginning SIM Unlock > Connecting to device... > Device already unlocked, nothing to do > Device already unlocked, nothing to do > Detected: HTC Elf/Elfin > Device already unlocked, nothing to do |
04-02-2012, 23:46 | #10 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | This is a bug on server side when coder solve it will be annocend I can't tell when this will be or if will be ever all depent from coder. |
04-23-2012, 16:58 | #11 (permalink) | |
Freak Poster Join Date: Apr 2004 Location: Antalya/Türkiye Age: 43
Member: 64224 Status: Offline Thanks Meter: 24 | Quote:
> Detected: HTC Elf/Elfin > Device already unlocked, nothing to do > Failed contacting server, this shouldn't happen, terminated. | |
05-01-2012, 16:35 | #12 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | > Operation Time: 40 secs > Detected: HTC Herald > Failed contacting server, this shouldn't happen, terminated. > Operation Time: 38 secs > Detected: HTC Herald > Device already unlocked, nothing to do |
06-02-2012, 08:17 | #13 (permalink) |
Junior Member Join Date: Oct 2006
Member: 376186 Status: Offline Thanks Meter: 0 | help!!htc artemis unlock I do unlock the phone with the htc artemis greetings axe box gives this error Failed contacting the server, this should not happen, terminated. Operation Time: 42 secs |
E71 strange probleme in mic | santosh4gsm | Nokia Hardware & Hardware Repair | 5 | 04-18-2012 10:39 |
Samsung b7722 Access violation at address in spt.exe[ANSWERED] | sheikh1777 | SPT BOX | 3 | 04-08-2012 09:40 |
How to get flash files for all Samsung Models | arif_2011 | RIFFBOX | 1 | 04-04-2012 11:31 |
GEVEY SIM AIO (All In One) - NO CUT Version - Official software release | MANOLE | Service Products News & Updates | 0 | 04-04-2012 11:15 |
