03-29-2010, 19:49 | #52 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | I think its a special convertor which ............. one is 8 pin tested by mxkey HTI interface 2nd is 10 pin tested by mxkey HTI interface 3rd is universal pinout for rj45 tested by mxkey HTI interface for future update ......... Last edited by sharmin; 03-29-2010 at 19:54. |
03-29-2010, 19:55 | #55 (permalink) |
Freak Poster Join Date: Oct 2004 Location: pontianak is good
Member: 87762 Status: Offline Thanks Meter: 30 | for interface for jaf box/ufs/mx key box and suport with good voltage and multi loader , corek me if i wrong 3GS = 3G speed .( higt speed adapter flasher like 3G ) |
03-29-2010, 19:56 | #56 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 68
Member: 169399 Status: Offline Thanks Meter: 28 | i-Pmart BX Series SMA Pro V2 comes with extra USB connection cable that solves all problems in flashing latest BB5 / BB5+ on JAF / UFS (It's not require external power supply). Putting phones into local mode with older cables. NOW SOLVED!! Features: * Get into local & test mode in just 5 seconds * Comes with 2 sockets (RJ45 and RJ48) No sharing sockets. RJ48 10pins for Genie / MT Box / GTi another one RJ48 10pins for Cyclone Box. You can now connect both cables as UFS cables. Prevents pins damages on RJ48 cables if plugged into RJ45 socket. Also damages of phones using VPP lines cables to TX2 lines are not possible. * No problem entering local mode by switching the correct resistance on BSI line (0K,2.2K, 3.3K, 4.7K, 5.1K, 6.8K, 7.5K, 10K) * Work on original Genie /GTi / MT Box/Cyclone 10pins (TX2, VPP enabled) cables * Work on JAF 7pins cables & UFS cable for Nokia i-Pmart BX Series SMA Pro V2 adapter allows you to power highly active and stable VBAT current output to phone when flashing through Genie /GTi / MT Box/Cyclone. It protect your box to have longer life without damaging it when working in low current and output high current to phone. This will allow your phone to enter Local or Test Mode very fast for unlocking and flashing |
KG270 flashing fails in 98% what can be the problem with it? | NawabN Sahoo | Infinity-Box | 1 | 08-31-2009 22:10 |
t650i the battery does not charge. could anyone give a clue what can be the cause? | barchuk | Sony Ericsson Hardware Repair | 0 | 10-14-2007 07:31 |
what can be the problem with optiflash, only read not write | sallu | Trident/AGERE Platform | 0 | 06-28-2006 19:33 |
