11-27-2018, 12:12 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | Error! [ data_not_accepted ] SOLVED Code: 12:05:26 > MODEL: my312X 12:05:26 > IMEI: 358021010385031 12:05:26 > FIRMWARE: EON,GJ: 110108 2039 12:05:26 > HASHTABLE: 842005 12:05:30 > Please disconnect phone from cable: OK! 12:05:30 > Please follow the next steps: 12:05:30 > 1. Power OFF phone 12:05:30 > 2. Remove battery from phone 12:05:30 > 3. Connect cable to phone 12:05:30 > 4. Put battery to phone 12:06:54 > Press power ON: OK! 12:06:54 > Reading cpu info: OK! 12:06:54 > CPU: LOCOSTO HS 12:06:58 > Sending loader: OK! 12:07:33 > Sending certificate: OK! 12:08:35 > Waiting loader answer: OK! 12:09:14 > Reading data: OK! 12:09:14 > Disconnecting phone: OK! 12:09:14 > Checking server 1: OK! 12:09:15 > Connecting to server: OK! 12:09:18 > Asking server for access: OK! 12:09:19 > Sending data to server: ERROR! [ DATA_NOT_ACCEPTED ] 12:09:19 > Disconnecting from server: OK! 12:09:19 > Sagem my312X READ UNLOCK CODE(S): |
11-27-2018, 12:20 | #2 (permalink) |
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | Code: 12:14:48 > MODEL: my312X 12:14:48 > IMEI: 358021010385031 12:14:48 > FIRMWARE: EON,GJ: 110108 2039 12:14:48 > HASHTABLE: 842005 12:15:07 > PRESS POWER: OK! 12:15:07 > READING CPU INFO: OK! 12:15:07 > CPU: LOCOSTO HS 12:15:11 > SENDING LOADER: OK! 12:15:46 > SENDING CERTIFICATE: OK! 12:16:26 > WAITING LOADER ANSWER: OK! 12:16:50 > READING DATA: OK! 12:16:51 > DISCONNECTING PHONE: OK! 12:16:51 > CHECKING SERVER 1: OK! 12:16:51 > CONNECTING TO SERVER: OK! 12:16:53 > ASKING SERVER FOR ACCESS: ACCEPTED! 12:16:54 > SENDING PHONE DATA TO SERVER: NOT ACCEPTED! PHONE ALREADY IN SERVER! 12:16:55 > SAGEM MY312X READ CODES: END! |
11-30-2018, 15:02 | #4 (permalink) | |
No Life Poster Join Date: Jan 2001 Location: StarSystem
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Quote:
You forget need press GET code after some time , if you not get it ? IMEI: 358021010385031 CODE: 37288162-50 | |
12-12-2018, 22:55 | #5 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | Code: 22:48:48 > MODEL: SG346i 22:48:48 > IMEI: 358199008427914 22:48:48 > FIRMWARE: LB5,DG: 210206 1010 22:48:48 > HASHTABLE: 508601 22:48:53 > Please disconnect phone from cable: OK! 22:48:53 > Please follow the next steps: 22:48:53 > 1. Power OFF phone 22:48:53 > 2. Remove battery from phone 22:48:53 > 3. Connect cable to phone 22:48:53 > 4. Put battery to phone 22:49:00 > Press power ON: OK! 22:49:00 > Reading cpu info: OK! 22:49:00 > CPU: CALYPSO HS 22:49:04 > Sending loader: OK! 22:49:38 > Sending certificate: OK! 22:50:57 > Waiting loader answer: OK! 22:52:36 > Reading data: OK! 22:52:36 > Disconnecting phone: OK! 22:52:37 > Checking server 1: OK! 22:52:37 > Connecting to server: OK! 22:52:40 > Asking server for access: OK! 22:52:40 > Sending data to server: OK! 22:52:47 > Calculating [by server] please wait: OK! 22:52:47 > Disconnecting from server: OK! 22:52:47 > MODEL: my411V 22:52:47 > IMEI: 355150015050713 22:52:47 > CODE: 19516614-42 22:52:47 > MODEL: SG346i 22:52:47 > IMEI: 358199008427914 22:52:47 > CODE: 31479107-39 22:52:47 > Sagem SG 346i READ UNLOCK CODE(S): END! |
The Following User Says Thank You to MDK23 For This Useful Post: |
