06-18-2016, 19:37 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | And where's the problem?... Select you Model LG "D920" aka LG Fino, then Set right how Sw prompt, (read carefully), and try to repair. Br allumts |
The Following User Says Thank You to allumts For This Useful Post: |
06-19-2016, 09:35 | #3 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Poland
Member: 372482 Status: Offline Thanks Meter: 93 | Code: 19:49:58 > LG L Fino D290N READ INFO: START! 19:49:58 > Please power on phone and connect to usb in android debug mode! 19:49:58 > If phone ask to allow usb debuging please accept! 19:49:58 > KILLING ADB SERVER (IF RUNNING): 19:49:59 > KILLING ADB SERVER (IF RUNNING): OK! 19:49:59 > Searching for phone: 19:50:01 > Searching for phone: OK! 19:50:01 > Reading info: 19:50:04 > Reading info: OK! 19:50:05 > BRAND: LGE 19:50:05 > MODEL: LG-D290 19:50:05 > L70PN / L70PN_GLOBAL_COM 19:50:05 > HWID: L70PN-6 19:50:05 > VERSION: ANDROID 4.4.2 19:50:05 > BUILD KOT49I.A1452595206 19:50:05 > FIRMWARE: L70PN_GLOBAL_COM-USER / MSM 19:50:05 > KERNEL: 3.4.0+ (lgmobile@si-rd10-bx33) (gcc 4.7 ) #1 SMP PREEMPT Tue Jan 12 16:26:53 IST 2016 19:50:05 > FINGERPRINT: LGE_L70PN_GLOBAL_COM_L70PN_4.4.2_KOT49I.A1452595206_1452595206_USER_RELEASE-KEYS 19:50:05 > PHONE SN: LGD2902A294C3 19:50:05 > CPU TYPE: MSM8610 / ARMv7 19:50:05 > SIM STATUS: NOT_READY 19:50:05 > Checking root: 19:50:07 > Checking root: OK! (ROOTED) 19:50:08 > LG L Fino D290N READ INFO: END! 19:50:23 > Checking server 1: 19:50:24 > Checking server 1: OK! 19:50:24 > Connecting to server: 19:50:24 > Connecting to server: OK! 19:50:24 > Asking server for access: 19:50:25 > Asking server for access: OK! 19:50:25 > Disconnecting from server: 19:50:25 > Disconnecting from server: OK! 19:50:25 > USING: MICRO-BOX A.I.O. NEW V4.0.0.2 19:50:25 > MICRO-BOX SN: 015B383F16000018 FW: 75/50 19:50:25 > PORT: Autodetect - 115200 19:50:25 > LG L Fino D290N REPAIR IMEI: START! 19:50:25 > Initialising data: 19:50:25 > Initialising data: OK! 19:50:25 > Detecting port: 19:51:01 > Detecting port: ERROR! [ PHONE_NOT_ANSWER ] 19:51:02 > LG L Fino D290N REPAIR IMEI: END! 19:52:20 > Checking server 1: 19:52:21 > Checking server 1: OK! 19:52:21 > Connecting to server: 19:52:21 > Connecting to server: OK! 19:52:21 > Asking server for access: 19:52:22 > Asking server for access: OK! 19:52:22 > Disconnecting from server: 19:52:22 > Disconnecting from server: OK! 19:52:22 > USING: MICRO-BOX A.I.O. NEW V4.0.0.2 19:52:22 > MICRO-BOX SN: 015B383F16000018 FW: 75/50 19:52:22 > PORT: COM24 - 115200 |
06-19-2016, 10:08 | #5 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, you answered yourself... and also: Quote:
06-19-2016, 10:13 | #6 (permalink) |
Member: 372482 Status: Offline Thanks Meter: 93 | The software says: Code: JOB: Repair imei CABLE: MICROUSB USB POWER: Phone must be ON 1. Dial/type 277634#*# 2. Go to "Port Check Test" (or "SVC Menu -> Port Check Test") 3. Set "Port Check Test" to "Enabled" That while I cant use them to get them repaired... |
06-19-2016, 10:30 | #7 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | So first try to reflash this phone with same Fw, this starting from NULL Imei, (modem damaged?), if cannot open SVC menu this phone can have some problem, Install RIGHT drivers for LG and later loock for SVC Menu... Quote:
06-19-2016, 10:40 | #9 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Solution i've given, not have this phone in my handles and what is been done for to have IMEI NULL and PORT NOT DETECTED.... so our Sw work perfectament, problem is in you phone, ceck what the problem in phone....only later can try to Repai Imei. Have a nice day |
06-19-2016, 11:36 | #10 (permalink) | |
Member: 372482 Status: Offline Thanks Meter: 93 | Quote:
Thanks for your help | |
