kaisser from at&T canīt unlock [Solved] Hi, I tried many many times, I install the app but, I canīt see the log VERSION MICRO-BOX A.I.O. V1.0.1.2 HTC TILT READ CODES: START! CONECTING TO SERVER: OK! ASKING SERVER FOR ACCESS: ACCEPTED! CHECKING HTC ACTIVATION: OK! HTC: ACTIVATED CHECKING MBTOOL INSTALLATION: OK! SENDING WINDOWS MOBILE LOADER: OK! STARTING LOADER: OK! PLEASE DISCONNECT USB CABLE: OK! PLEASE RECONNECT USB CABLE! SEARCHING FOR PHONE: OK! READING MODEL: OK! SENDING LOADER: OK! READING IMEI: ERROR 1001! RESTARTING PHONE: OK! HTC TILT READ CODES: END! now? how can I unlock that? Any solution? br. malacatonche |
you can unlock this phone with software for free........br |
I know that, but with this phone I canīt I donīt know why not, but I canīt. in fact I want to try with microbox. any other solution br |
http://forum.gsmhosting.com/vbb/showthread.php?t=884638 |
Yes, I tried with this metod, in fact I have 3 kaisers,, two of the sayme error 10085, and the other one, is the phone of the log, in any case I canīt use microbox for unlock, in the 3 cell, I tried before and after did a hard reset but, I canīt. thanks |
1 - Install Microsoft Activesync on your computer 2 - Download latest microbox Archive from support, inside this file you can find the HTC Micro-Box Tool.cab. 3 - Connected Your HTC at your computer with Activesync 4 - Copy the HTC Micro-Box Tool.cab file to your phone 5 - Install the file on your phone. 6 - Run Microbox ALL In One software, and Select your Modele in list : Press Read code ! If this not help you , contact me via PM , we will check |
Yes This Is Working Fine Solution |
donīt work I tried in 3, notebooks, some kaises has win mobile 6.0 the other ones, 6.1, in fact donīt work, I think, the problem is with the algoritm, of the software, becouse I tried , with bb-box (polar team algoritm) and I canīt either. with bb-box the phones hangs when the app is apploading......the proble is in the app. other solution? br. malacatonche |
HTC S730 can't unlock. Please help me: http://forum.gsmhosting.com/vbb/show...14#post5173614 |
nop all are original, no flashed, and some in win 6.0 other in 6.1 |
ive just managed to unlock a HTC KAISER kais130 with v2024. It was simple and no needed to upload Tool.cab file or anything coz it did it all automatically. Just have to press YES on phone screen when it appears, and make sure ACTIVE SYNC is installed on comp. Once you get the codes, then put in wrong sim and first enter the NCK and after it will ask for SPCK, then enter that. they both might be the same code anyway, as mine were: 12:37:05 > VERSION MICRO-BOX A.I.O. V2.0.2.4 12:37:05 > HTC KAISER READ CODES: START! 12:37:06 > READING ACTIVATIONS FROM BOX: OK! 12:37:06 > HTC: ACTIVATED! 12:37:06 > CHECKING MBTOOL INSTALLATION: ERROR 1005! 12:37:06 > PLEASE ACCEPT/CONFIRM INSTALLATION ON PHONE!!! 12:37:31 > INSTALLING HTC MICRO-BOX TOOL: OK! 12:37:32 > CHECKING MBTOOL INSTALLATION: OK! 12:37:51 > TRYING TO READ DATA BY EXPLOIT: OK! 12:37:51 > IMEI: 35575701765720202 12:37:52 > CHECKING SERVER 1: OK! 12:37:52 > CONNECTING TO SERVER: OK! 12:37:52 > ASKING SERVER FOR ACCESS: ACCEPTED! 12:37:53 > SENDING PHONE DATA TO SERVER: OK! 12:37:56 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 12:37:56 > MODEL: Kaiser 12:37:56 > IMEI: 35575701765720202 12:37:56 > NCK CODE: 57968914 (SIM network unlock PIN) 12:37:56 > NSCK CODE: UNLOCKED (SIM network subset unlock PIN) 12:37:56 > SPCK CODE: 57968914 (SIM service provider unlock PIN) 12:37:56 > CPCK CODE: UNLOCKED (SIM corporate unlock PIN) 12:38:03 > RESTARTING PHONE: OK! 12:38:04 > HTC KAISER READ CODES: END! |
It's uploaded automaticaly by soft now. Good job. WBR, gsm9l;) |
